Getting a vibration 62-70ish. Measured angle with phone and shows it at 5 deg down from DS. Going to order 2 degree wedges to replace my 4's. Looks pretty straight up at 0 deg to me though. Vibration goes away by 75. Smooth as anything at low speed which has me thinking not the driveline. Doesn't change on deceleration accel. Problem is I feel like it started when I messed with the rear springs.
Centering pin is tight. Around 2.5 yrs 15k miles on tom woods shaft.
Already rotated tires. Checked u joints. Replaced one due to noise. Confirmed u joint phasing. Driveshaft shop said shaft is slightly bent but I'm trying to make sure that's the issue before shelling out $350 for a new one...
Never drove in FWD only with rear shaft removed. Any concerns doing that at 65 ish??
Sent from my SM-G960U using Tapatalk
