meanwire
Hello, I have a 1977 Bronco and the brakes are acting up. Just recently I've notice the brakes are getting horribly worst. Use to be very sensitive brakes, now there is so much pressure to even apply the brakes. I've checked brake fluid and bled all 4 brakes. Pumped the brakes to build up pressure, crack the drain to relief any air while holding the brakes down then tighten up the nut. Thinking this would help but not go. Like I stated I almost cant depress the brake and the pressure is back? No I haven't looked at the front brake pads yet. This brake issue also started when the bronco started running real crappy. What I mean by that is it idle's real low and dies sometimes at a stop unless I put my foot on the gas pedal. I just thought maybe I needed to adjust my carb. Notice also when I start the Bronco in the morning that it has a hard time running, choke doesn't kick in. So with that can you guys help me pinpoint the vacuum leak. Thought I'd ask before diving in deeper and a fellow member can help me. Any suggestions or advice would greatly be appreciated. Thanks!
