C4 input shaft question
tonytheplumber
Lowell, IN
So I got my trans back from the rebuilder today and realized that the hole in the end of the stator is supposed to house an input shaft. I don't know if the trans from this project truck ever even had an input shaft, but I know it doesn't have one at the current time. I don't think I would have misplaced it, but if it was in the old torque converter when I trashed it and somehow didn't catch that, it's long gone. So, due to past experiences with ordering the wrong parts I'd like to know if one of you gentlemen would happen to know what input shaft I need? As in, what application is the correct one. Do I need to just do a spline count?? Are they all the same?? Are there different lengths? I learned my lesson on the flex plate and starter debacle I just went through. I don't want to be ordering the wrong part. AGAIN
Thanks in advance!
Viperwolf1
electron whisperer
The 64-69 input shaft is 24x24 spline and smaller in diameter than later shafts. The 70 shaft is 26x26 spline. The 71 and later shaft is 26x24 spline. All Bronco C4s had the last one, when they left the factory.
bax
Old Member
FordBronc, The OP was asking about input shafts. You are posting up tail shaft adapters. All good info but lets understand were looking for an input shaft. Viper had some good information. I have had the input shaft problem before. You don't always get a "Bronco" transmission in a bronco. The OP needs to figure out what year c4 he has so he can get the correct part.
And possibly what year parts were used in the rebuild.
I would ask the rebuilder if they have an input shaft for the transmission. Good chance they have one just laying around. They are a loose part. No retaining clip or anything. Just slip it in.
Rustytruck
I ran into this problem swapping out a wrecking yard C4 when I was a young one in my 67 Mercury Caliente. All the shafts look the same to the casual eye. Converters look the same but swapping parts gets goofy. Ford does this on purpose to mess up your day on a simple project.
FordBronc
Bronco's, yea I have a couple.
Polk County, Missouri
Yes oops it was early and my coffee was not done...in fact I think I was still asleep even though I was already at work. lol
tonytheplumber
tonytheplumber
Lowell, IN
I did a spline count on each seeing as how I don't know the cobbled together history of this truck. The trans is indeed 24 spline (technically 22 since there are 2 blanks ;)) and the converter is 26. I ordered a new TCI piece from Summit.
True story on not knowing whether of not this is a Bronco trans. Lord only knows.
He didn't have any laying around. He builds a lot of high performance torque flights so he likely has scads of old mopar parts laying around.
They have ruined my day on many occasions lately :mad:
All good. I greatly appreciate that you were willing to post those links in an effort to help out.
Viperwolf1
electron whisperer
Post some pics of the trans. The shift lever is unique to Broncos. There is a date code cast into the case above the shift lever. All Bronco C4s also had an H cast into the servo on the right side. It should also be a pan fill case. Bellhousing attaches with 5 bolts separate from the pump bolts.
71sport408
Mandan
These fellows are much more knowledgeable than myself but I have purchased and used C4 input shafts from Performance Automatic. Not sure what amount of horsepower you are putting it behind but I ended up going with a hardened input shaft. This was a while ago however so I can’t attest to their current offerings. Just thought I would throw it out there.
tonytheplumber
tonytheplumber
Lowell, IN
Look like a Bronco trans?? I currently have the bell removed while I sorted out my starter and flex plate issues. It does NOT share fasteners with the pump. And this is a pan fill model.
Sorry the pics came out sideways :(
tonytheplumber
tonytheplumber
Lowell, IN
I ended up ordering a hardened shaft by TCI from Summit. I doubt I will be making enough power to hurt a stock shaft, but I would hope the hardened shaft would be as strong if not more so than stock. I definitely did not want the cheapest one I could find.
