Suffering a very similar issue as Ibuch but have been following the thread closely and made some changes and have a new possibility..
-Acts fine for a while and then, over time starts to drag, but to the point to where I can pull the pedal back up just slightly with my foot to get the brakes to free up. I can slow to a stop and they are dragging, but pull the pedal back just a hair to the stop and you can feel them free up
-Plenty of room around the calipers and have checked them hot as well
-Went back and adjusted all the linkage from the pedal to the booster to ensure it's tight and as per directions
-Booster passes all advised tests, such as builds and hold pressure with engine off and pedal falls when engine starts
-Pulled the master from the booster (purchased as a complete kit) and found that the master would not sit flush with the booster due to the pushrod. I ended up removing the locknut from behind the threaded pushrod end which got the master flush. Retracted the pushrod end to about 1/16" gap and bolted the master back up and re-set brake pedal to the stop
-Re-tested system and while brakes felt more responsive initially, over a stop and go drive the problem started again, to where I could simply pull the pedal back ever so slightly with my foot to free the brakes
-After cussing and staring, I have a new question to the pros
-PO has chrome full length headers installed. I added the power brakes, including a new prop valve and pre bent hard line from the prop valve to frame mounted block. It was very close to the headers so I wrapped the pipes with exhaust wrap above and below areas where the brake lines seemed close.
Since the problem surfaces only after driving for a while, I am thinking that the lines are getting to hot from the headers and causing the fluid to expand. The line from the prop valve going down to the block gets hot, but you can still hold your hand against it for a second, but the prop valve gets overly hot to the touch.
Also after the last drive when I got back and popped the hood, the master was pushing fluid out to the point there were a couple of drips on the fenderwell. (Always great to find)
So I'm wondering if, in spite of the wrap, as the problem surfaces the longer I drive (heat builds) if the fluid isn't getting too hot in the line and starting to force the caliper.
-So, as brake fluid is rated at high temps, is this a possibility? And if so, for those who have headers, are there any other mods like shields you've added?
-If the heat shouldn't be a factor then what next?? Could it still be the booster?
Thanks much for the help
