Over/under
brad smith
tupelo ,ms
Got a question. I can't remember does the cargo bed plate rest on top of the rear floor support or does it go under the rear floor support. I know it goes on top of the rear next to the tail lights. But what about the front area. Thanks in advance !
Speedrdr
Learning Member
Paris, MS
If I looked at my 77 correctly, it goes on top at the front as well. The PO coated the entire inside of the interior with bed liner so it was a little hard to be sure without getting a grinder ahold of it. Maybe someone that has an unmolested bed surface can correct me if I'm wrong.
Randy
brad smith
brad smith
tupelo ,ms
Floor lips
Randy
Thanks randy. It's makes me have mixed feelings about it. Cause the floor has the lips on each side. So if it goes on top like the rear. The lips will have to be trimmed away enough to clear the support. Just wondering
Attac
At the front it goes under the upper seat deck floor panel and just about butts up to the rear seat deck support channel
Chuck
Attac
Here is a pic of where I think you are talking about
brad smith
brad smith
tupelo ,ms
Support
Thanks chuck. So you are saying it doesn't weld to the rear floor support it welds to the floor sheet metal?
brad smith
brad smith
tupelo ,ms
Rear floor.
Yea that is the area in the pic. My floor was rusted pretty bad. And couldn't really tell where it need ls to be welded at.
Attac
Yes it originally had spot welds about every 2"
You should be able to zoom and see all the spot weld cutter holes on the last one I replaced
brad smith
brad smith
tupelo ,ms
Support
Thanks chuck. So with it just being attached to the front floor is enough? I just figured it needed more support than just spot welded to the other floor. But it seems like you done a quite of few. Thanks again
Attac
Yes
By the time you attach to the corner fillers and the fender tubs and the front it is plenty sturdy.
Good luck
brad smith
brad smith
tupelo ,ms
Floor.
Thanks I looked at it you are correct. It looks like I may have to cut the front part of mine to make it line up with the rear holes indention in the rear. Does that sound right?
Attac
There is usually trimming involved to make any repair panel work. Just be sure you have looked at each end really well to make sure where to trim.
Look at a few of the build threads here that have shown major floor repair to see what has been dealt with before. Jefe, Rydog are a couple that come to mind. Also Englewood cowboy does this professionally and has a good build thread to look at. I lurk very often to find an install that looks like what I am dealing with. Not any two Broncos are exactly the same. Close but not exact
Chuck
bronkenn
Bronco Guy
Southeast Ohio
From the factory the rear floor was welded under the front floor but when I redone mine I welded the rear floor on the top of the front floor. My thinking was the joint would be facing towards the rear and water wouldn't get forced into the joint while driving. I think either way will work. Ken
74 Bronco Billy
Either way will work, but if you are going for original look, that under. But I am with Ken, it is one less seem running looking forward for dirt, mud, rocks, etc to get put into.
Go slow on those big sheet panels, tack carefully in many places, let it cool slowly and fully. Otherwise you will get warpage. Plenty of screws or Cleo’s or vice grips too ;D
brad smith
brad smith
tupelo ,ms
Thanks bronco billy.
Yes sir that's true. Do you put the main floor in before you put the fillers in each corner or do the fillers go in first. Thanks
Attac
Put floor in and kleco or clamp as well as a few tack welds you can get to easy. Then fit your corners in and tack them in. You might need to work them a little to get them to fit. After your happy with everything then weld it up all around by alternating where you weld so not one place gets too much heat to distort.
There will be some gaps and holes in the front corners against the door jamb area. That's how they are designed. You use seam sealer on these spots or make little fillers.
Take your time
