broncodude_73
- Feb 21, 2005
- 77
Im not big on takin pictures so this is what i got. Basically I've built 2 lower control arms and on the passenger side i built an upper arm comin off the lower to set caster,camber,and pinion angle. All the links are adjustable as of right now except for my track bar which i will come back later when i have time again and put a heim joint on the axle side.
the whole reason i started this project was because i broke an axle shaft u-joint in shiloh ridge so i figure while i got every thing tore apart i may as well build a new suspension put chromo shafts up front and finally step up to a detroit, and it was worth all the work.
It took forever to build these damn shok hoops, but i think they came out nice. I took the 6'' lift shocks off of the back of my powerstroke and stuck um on the bronc to make the katemcy run. I ordered another set when we got back cause they worked perfectly.
I love it.
I also went ahead and disked my rear 9'' and shaved the housing for more clearance.
it made a huge difference just a little more ground clearance.
