NV3550 Install
904Bronco
San Martin, CA
I just finished installing a NV3550 in my 77. It originally came with a C4 and I was fortunate that my neighbor down the street wanted to convert his 3-speed 72 to an automatic. We just swapped parts... ;D I also have a 75EB with an AOD, so I wanted to do something different. I have been very pleased with the conversion and would recomend it to those who might be interested. I have listed some things below that I had to do. I did alot of research on past threads, so I do not feel that I can take any credit for the things I listed. Someone else did the work, I just put it all together. Thanks to MarsChariot for his Tech write-up and everyone else for posting their info, it was all very helpful.
Doug
• The fill/drain plugs on mine needed a 19mm allen to remove them. I made one out of a metric bolt with a standard threaded nut welded to it. Put a socket on that…
• Set the pilot bushing in as deep into crank as it will go to give you 1/8” – 1/4” inch more clearance. If you do not, there may be binding where the input shaft tapers back up in size.
• The pilot bushing needs to be soaked in oil overnight.
• I did not have to cut ¼” off the tip off my transmission shaft. I measures tolerances multiple times.
• I bench fitted everything together before putting the assembly in my rig. I put the transmission in first and then added the T-case.
• Buy an alignment tool for a 10 spline disk with a .75 inch diameter pilot bushing center
• I used a 164 tooth, 50 oz, 11 inch flywheel as I have a late model motor in my 77. I was told I could use a flywheel from an 87-91 F-series Truck with a 5.0. After I looked at a new one at NAPA (China), I elected to buy the one from WH which in made in the USA.
• I was told by my pressure plate supplier that the 76-78 trucks had a unique mounting bolt pattern for the pressure plate, most suppliers use a Chevy style bolt pattern which is more common. The WH flywheel was drilled for the unique pattern.
• I used silicon sealer on the flywheel bolts to the crankshaft; this is to prevent oil leakage and was recommended by my engine builder.
• I would recommend running a tap through all the threaded holes to clean up the threads. Do this in the bellhousing, transmission, mounting holes on the frame, etc. I used anti-seize or loc-tite on almost all of my bolts
• I bit the bullet and used the Chrysler trans fluid, you need 2.5 quarts to fill the transmission.
• I cut a 5 inch square hole in the center of the Trans hump on the body. It is a little larger on the driver’s side because of the existing transfer case shifter hole. I made a cover plate to screw down on the body over this hole as suggested in the NV3550 write up in the Tech section. In the front, I cut right up to the body support, but not into it.
• I cut an inspection hole on the driver’s side of the transmission hump with a holesaw; I then cut down the 5x5” piece I removed from the top to make a cover plate. This gave me access to the twin stick shifter mounting bolt.
• I used the twin stick boot from WH and I found a Hurst boot at AutoZone for the transmission shifter. The Hurst boot is mainly a dust/dirt boot, one day I will make a nice one like MarsChariot in the Tech write up. (Hurst # 114 7336, B1 boot and plate. Turn the plate over to not see the Hurst logo)
• With the 1 inch body lift in place, I placed the factory clutch rod next to the adjustable WH rod and made it 1 inch longer. This was my starting point for my clutch adjustments.
• I had to heat and bend (at the existing bend) my transmission shifter from A/A as it hit the dash pad. The first shifter from A/A did not fit my Trans, as mine had the square mount. A/A were very good to work with; they sent me the correct one and a return prepaid UPS label for the wrong one. They make 3 shifters, so you need to make sure to tell them what you have.
• The A/A NV3550 rear adapter now has 3 positions (threaded holes) for clocking the D20; you must use the center (factory position) hole in order for the WH twin sticks to work.
• I have a J-shift D20, the A/A kit is designed to work with the T-shift D20. With the J-shift you must use a twin stick set up. For my rig on the A/A T-case shifter mounting bracket: I had to drill a new hole ¾ “directly above the threaded hole A/A had put in their bracket. I then tapped that hole for a ½ x 13 bolt and used the pivot/mounting bolt that was supplied by A/A instead of the bolt that came with the WH shifters. (Same bolt, it just had the threaded end cut down.)
• With the A/A shifter bracket, I had to round off the top (shifter side) of the bracket for shifter clearance. Basically, 45 the corner instead of 90 degrees. I also had to notch the transmission case webbing just a little, near the top of the bracket support, for the proper fit.
• I had to heat and bend the twin stick shifters for clearance from the transmission shifter. This was done at the existing bends and it did not require a lot of movement.
• I felt most of the bolts supplied in the A/A kit could have been longer, there was room, I purchased longer grade 8 bolts and hardware. This was a personal choice and is probably over kill on my part.
• The supplied A/A crossmember was well built, but the paint was scratched up. I tried to do some touch up with some black Krylon and the factory paint lifted. A can of brake clean removed all of the factory paint and I repainted the crossmember.
• My catalytic converter had to be moved back about 3 inches, a short extension welded to the factory Y pipe and shortening the pipe between the Cat and Muffler.
• I ended up rebuilding my D20 so I upgraded with WH - HD output shaft. This caused me to have to shorten the rear driveshaft. When I got it to the Driveshaft shop I found out it was toast, so now I have a brand new one…
• Wiring: I had a C4 before my conversion and the neutral safety/reverse wiring harness went with the transmission to my neighbor. My 77 had a rubber 4 prong plug from the main harness to the C4 harness. Fortunately for me, I had another 4-prong plug in my box of junk. I wired the neutral safety wires together with this plug and extended wires down the transmission. I already had a GM Weather pack plug, which I wired up the transmission reverse light plug.
• I found, at least with my rig, that I cannot down shift the Trans into 2nd unless I am 20 mph or less. It grinds…
• The transmission feels good with 3:50 gears and 31x10.50x15 tires. RPM is around 1900 @65mph. I have a Carburetor now and I am looking forward to my EFI conversion this summer.
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
Doug,
Congratulations on a great write up! And on getting the installation done! These are excellent additions to the NV3550 tech data base. We should see if we can get Jon to add it as an addendum to my existing NV3550 installation tech article. You can never have too many view points and experiences on these things.
Way to go Doug! Glad to see one more thing out of the way.
For now...
904Bronco
904Bronco
San Martin, CA
O.K. This might be a dumb question, but why do you need to soak the pilot bearing in oil overnight ?
The "Pilot bushing" needs tp be soaked in oil, it is not a bearing. The material that the bushing is made from absorbs the oil and you do not have to put any grease on the shaft prior to assembly. Lifetime lubrication I guess?
Pretty much it. But there ARE actually bearing versions out there. Have one in mine in fact. It's basically a caged needle bearing type setup and comes pre-greased. Presumably for the life of the bearing.
Personally I prefer the old style bronze(?) bushings soaked in oil, like Doug's talking about, instead of the bearing. Just seems more reliable in the long run.
Though I guess I can't talk much. Mine's got about 70k on it and didn't make any funny noises before I stopped driving it.
Guess that's because the pilot bearing/bushing is only actually in use when the clutch is slipping.
scotts77
Marietta, GA
Yea, that was the point of my question. I am also doing this conversion and am going from a needle type to the provided bushing. Thanks for the reply and write - up.
