'69 Build Up *Paints done, body's back on with poser pics*
hammer
Well now that I finally became a contributor I thought I'd transfer my build over to this site from my local one.
Purchased this '69 Bronco in the spring of '06 and am just over a year into digging into it. Goal is to have a decent looking rig that I can have fun with and take the family camping and hopefully do allot of long road trips with.
Here's what needs to be done, goal is SOB in late August. (ha, ha, ha,)
- Mustang 5.0L MAF EFI swap - Engine's in. Needs to be wired etc
- ZF tranny - done
- Np205 - done
- Swap out the d30 for a d44 - done
- Front Disc brake swap - done
- 2" body lift - done
- CAGE 5.5" suspension lift - done, went with wildhorses system 7 5.5"
- CAGE Extended Radius Arms - done, went with bronco bob's arms.
- CAGE Double shock hoops - done, went with wildhorses extreme hoops.
- '76/'77 Power brake setup - still to do, have the booster and bracket.
- F150 Power steering setup - box is in, need to order wildhorses drag link, have all components for flaming river setup.
- 4.56's - done, went with 5.13's
- Replace front floors - done
- Replace kick panels -done
- Replace front inner and outer fenders - done
- Replace front Door Posts - done
- 6 point cage -have it in primer.
- Exhaust -still to do
- 23 Gal EFI tank - have one. Needs clean up and install
- Custom driveshafts - still to do. Pinion angles need work.
- Blast body and paint it. - Done!.
- Will be on 35's to start as I have a set. - just got new Toyo Open Country's 37x14.50x15's!
hammer
hammer
This is what I started with.
hammer
hammer
Removing the tub
hammer
hammer
Bare Frame. Hidden problems are revealing their ugly head....
hammer
hammer
Frame repairs and additions.
hammer
hammer
Rolling Chassis Again!
hammer
hammer
5.0L and ZF installed.
hammer
hammer
NP205 installed and ZF notched for shifter rail clearance. Custom bracket fabbed for NP205 side frame mount. Had to shim up the transfer case so the front driveshaft would clear the BC Broncos ZF crossmember.
hammer
hammer
Tossed the tub back on to start the body work. Thought I'd see what the cage was gonna look like.
hammer
hammer
F150 Disc Swap
hammer
hammer
Drivers side body panel replacement
hammer
hammer
PS side body panel replacement
hammer
hammer
New (to me) Toyo Open Country 37 x 14.50 x 15's!!!! I love them!
tinytim02
That's some nice work there....
Keep the pics coming...
Tim
Baja71
LOL, yeah the hardest part is getting the paint to dry;)
;D ;D ;D Ok, I do have a serious question though. I noticed you didn't do anything with the inside of the frame rails. Is there any danger of rust creep or rot, or am I being too anal? I have fantasies of taking great pains to coat the inside of my frame when I get to your level, but if it's not necessary.....
sstlaure
Bronco Slacker
We dragged rags soaked in paint through the frame rails of my friend's truck when we painted his frame.
hammer
hammer
I would love to but short of it getting dipped I don't know how you would go about it. Its going to be garage stored the rest of its life and things look solid now.
hammer
hammer
Well besides putting on the new rubber I had'nt worked on the bronco since the first week of November. Went hard on it today and got the Passenger side panels put it.
My dad has an old rotisserie that he used for restoring his '69 340 dart gts convertible. I'm going to pick that up next week and start modifying it to work for me. Then it's off to the blasters. Pretty stoked!
