WyleCoyote
- May 2, 2002
- 1,739
Wyle E Mobile Build up - IT RUNS!!!!
Hi All,
I am finally, Really, truly, and for sure getting the build on!!!
Where I'm at - Pics in my gallery I'll get my contributorship soon so I can post in here:
1974 Sport -
No engine - was a 302, down to brass on all the mains and ridged badly in all 8.
C-4, Dana 20 T-case - on the floor in the corner, they were fine 3 years ago, so I should be able to clean them up, lube'm and put em back in
Dana 44 and Ford 9 - still fine -
Frame - Hacked up front driver side rail and cross member. I have a replacement -
Body - No rust, mostly straight, crappy paint. I took the front quarters and doors off, and have the paint stripped off of them.
Interior - Dash is straight and rust free, bad paint. Tub is herculined, poorly. Seats are stock and worn out.
Suspension - Stock, but I have an NHL body Lift(Pucks)
Where I'm going -
Replacement frame - I already sandblasted the top and side of one rail - took about an hour and 1/2. Will get that done this week. Then it's POR-15 and Chassis black. 3/18/08 DONE!!;D
Body - After sandblasting I realized I was in over my head in this so off to the body shop it went. Ok - Body guy hasn't touched it at all, so I am probably going to pull the plug on that, bring the tub home, slap some paint on it and get it on the road
Interior - Strip paint from dash and repaint (Again any suggestions?). - Found some rust on the floor pan, and removed all the bed liner - Also replaced drivers floor pan and patched some holes on passenger side
Getting stock seats re-covered -change of mind I am going aftermarket for the fronts, and I dug out the rear seat and it is just fine!
Engine - Going to find a good used 302 for now, I want to build a 408 eventually. - I got a 91 Grand Marquis 5.0 with an AOD 6/9/08 BCB 23 Gal efi tank purchased with new efi fuel lines
Transfer case - Twin stick. Maybe go up to a NP205 when I get the 408 done.
Rear Diff - I really want a selectable locker - that is waaaaaay down the road though. Got a new 3rd member with a detroit and 4.56 gears for the 9, D44 goes into Randy's R&P soon for an ARB and gears.
Steering - F150 PS box, need new Tie Rod/Drag Link. - I have a 4x4x2 setup just have to put it together
Suspension - 3 1/2 Inch lift (I have Duff Coil Springs for the front) Need new leafs for the rear. The new frame had the Shock mounts removed, so I will be getting something - thinking Hoops(Duff, BC, Cage, I'm not sure) for the front, and something like the Duff Stage 1 rear shock mounts. Don't really want or need double shocks though... Shocks will be Bilsteen. Probably stay with the NHL Body lift. - F250 Shock towers in the front and a BC inboard shock hoop for the rear. Done. 6/9/08 BCB 3 1/2in lift front coils and 9 pack rear springs purchased.
That's the big stuff...I'm sure there will be thousands of other items that I will find and replace or upgrade along the way! But I'm motivated and it's starting to get done!!!
Edit 4/2/08 - Here are some progress pictures of where I'm at so far...Still working on it, waiting for the weather to warm up so I can start stripping paint!
Edit 6/9/08 - Part of the BCB order received. Pics on the last page
Edit 8/8/08 - Been really busy at my paying work, so not much done...but the tub is all blasted, and I got the floor pan out!
Edit 3/1/09 - Assembly is well underway, should have rolling chassis by the end of April - I am getting some long arms fabricated locally and getting some help installing the ARB and gears in the front but that won't be done until april.
Edit 5/25/09 - Ok had to wait to get my radius arms extended - so rolling chassis took a bit longer, but the D44 is regeared and locker installed - Got some shiney new Tires and Wheels, Getting pretty stoked to get back on the road!!
Hi All,
1974 Sport -
Where I'm going -
