Dusty
- Jun 28, 2001
- 2,965
Many of you know this harness from the eBay sales under the name "4wheelinjunky". West Coast Broncos is now a dealer for these and all products manufactured by Northwest Autowire. From now until the end of April, we will be offering these at a special introductory price of only $179.95, that's $20 off the already dirt-cheap regular price of $199.95!
We'll also be conducting a give-away here on Classicbroncos.com for a FREE HARNESS! The give-away and the special offer will expire at the same time, so if you need one anyhow don't wait around to see if you've won! We'll gladly refund or offer store credit if you purchase a harness then win the give-away.
Check out the T3-Bronco harness on our site at this link or check out the info below. The website price reflects this special offer so go there and get one for yourself before the prices go back to normal ;D Here's the photo and description from our site, if you have any other questions about it please feel free to email me at dusty@wcb4x4.com.
West Coast Broncos is proud to offer an affordable alternative to the expensive aftermarket wiring harnesses on the market. This kit from Northwest Autowire is perfect for everything from basically stock to highly modified Broncos. Unlike other low-cost "universal" harnesses available elsewhere on the web, 80% of this harness comes cut to length, taped, loomed and terminated just for the Bronco. But a more generic wiring scheme is maintained in the dash area and engine compartment, where most of our Broncos are far from stock anyhow. Using this harness you can customize your dash and engine wiring to suit your specific rig's custom modifications, rather than paying hundreds of dollars more for a harness that is set up for OEM equipment you no longer have and will have to cut out or alter anyhow. And for those whose Broncos are still intact as Henry intended them, this harness is still easy to configure for the stock instruments, switches, etc.
This kit includes circuits for headlights, front markers, front signals, taillights, brake lights, rear signals, back up lights, main fuel tank sender, starting system, ignition system, oil pressure sender, temp. sender, instrument lights, heater, wipers, horn, and spares for additional accessories! Also included are an integrated 40 amp accessory relay (for off-road lights, electric fans, fuel pumps, etc.), a 30 amp circuit breaker for wipers, signal flasher, hazard flasher, dash mount ignition switch, and late model ATC/ATO blade style fuse block with fuses and wires installed. All the wires are color coded, with many of them printed every few inches with the name of the circuit. The kit includes detailed, easy to follow instructions with color wiring diagrams.
While you're on our site, check out the rest of our growing selection of electrical-related items, including components for both OEM and custom dash installations.
Dusty
![20605a-400.jpg](http://www.wcb4x4.com/mm5/graphics/00000001/20605a-400.jpg)
Dusty
