Madgyver
Bronco Madman
- Jul 30, 2001
- 14,704
What is the going price on Unimog axles complete?
Front and rear?
What gear ratio do you have in the front D60 to match the gear ratio in your mog9?After doing A LOT of research, I decided to not use the 404 axles in their stock form. I decided to build a hybrid mog/9 for the rear. 9 inch center section with mog boxes. I converted them to disc brakes to avoid the common over heating problem and to provide better brakes. I turned down two stock long side axle shafts to 35 spline and I am running a Strange large bearing center housing with ARB. I am running a 2:47 R&P and then I have the reduction of 2.17 in the portal boxes. Now I can drive over a 5 gallon bucket and not hit it! ;D
truly amazing as always patrick!
patrick, How did you do that 9'' rear gear case. Strange dosen't make a High pinion 9'' But you seem to have one? Is this housing just flipped over. Are you running a reverse cut gear? If so what have you done about the side ? ring gear deflection support? I have not seen anything like this in a strange gear case.
bax
