Delay wiper squirter
Rollin
Port Angeles, WA
I am trying to hook up the delay wiper box I just bought, which everything
works like its supposed to but---- I cant get the squirter to work. I did notice
were the wires plug in there is one slot open with no wire on either plug that plugs into the stock harness. Does that mean I need to add a wire in there
and the squiters should work? The old switch worked fine.
Mark
Rollin
Rollin
Port Angeles, WA
Well that was out of the question because the new wiper switch doesn't have
a ear for that wire to go on to, it looks like its factory made so it connects with one of the center wires.
Any Ideas, does everyone else's work fine or do you make up a manual switch.
Mark
Viperwolf1
electron whisperer
As I recall there may have been a wire that needed to be moved in the delay connector. It was about 10 years ago. Anyway Ford was pretty good about keeping component wire colors the same across different models/years. The bronco washer wire is the green-black stripe wire. Do you see one of those in the delay plug?
Here's an old thread: http://classicbroncos.com/forums/showthread.php?t=104171&highlight=wiper+delay
This one has the answer: http://classicbroncos.com/forums/showthread.php?t=90229&highlight=wiper+delay
Rollin
Rollin
Port Angeles, WA
ok, from the bronco harness there is a green/white wire that plugs into the delay switch which is the one that is blank so it looks like the pump isnt getting power or something.
From the delay switch the black/green goes to the orange/white strip to bronco harness
Rollin
Rollin
Port Angeles, WA
Viper,
Thank you so much that was the trick, what a piece of cake to install and everything works perfect.
All I had to do is move the black wire/white stripe to the blank spot and
the pump works again.
You just made life easy again.
Mark
rjlougee
I did a write up on this back in the day, even posted this pic to help:
Posted that in Mar 2002.
Joe
