- Jun 4, 2002
- 35,518
OK, been working on this for some time. It is actually for another project but it works good enough I decided to share. Went through some other versions that sucked very bad. This one is actually working out very nice. If I were to do it again there is little that I would change. In fact about all I would change is the transition between the collector and the bypass should angle a little better and not be so perpendicular. A little wiring change for the compressor cycling as well.
OK, what you are looking at is a nice quiet stock replacment muffler for a Dodge Dakota (or was it a Durango?) Anyway it is for a factory V8 and is quiet. That is good 95% of the time. But there is a little trick. That pipe you see is a bypass around the muffler. Uses a big, cheap ebay wastegate. 50mm in this case. All it does is open a second route around the muffler. Does not close off the muffler, it can still flow. But it just offers a secondary way around the muffler for both flow and sound.
There is a small compressor from an air ride system from some junkyard car. 30 PSI oil pressure warning light switch wired to a relay to cycle the compressor. A MAC valve (search cheap ARB solenoid replacments).
The compressor has a little resivior and the oil pressure switch (cap was drilled and tapped to go from the propritary fitting to normal pipe fittings) to keep 30 PSI, waste gate is rated for something like 15 PSI. Putting 30 PSI makes it open all the way. Power the solenoid, wastegate opens fully, good sound. Release and it is civilized to not bother the neighbors as you leave at 5AM.
Best part, no drone! Even with 3½" full length exhaust. Before it droned no matter what I did to the exhaust. With that big of a pipe it is to be expected. But somehow this does not. Even with the bypass open, it still does not drone. It has a good sound with the bypass opened, I can hear it reverberating off block walls as I drive past. closed, makes for a perfect civilized sleeper. All for about the cost of an aftermarket "performance" muffler. Just takes a little longer and more thought to install. Not for the normal brain dead hotrodder who buys all there stuff from catalogs.
