a few more pics. Sorry I had to use my phone, its all I have available. The hinge is a pin for tractors and is rated at 3,000lbs. it is geasable and the brace keeps it from swinging past about 190 deg. so it doesn't need saftey straps. The latch is a simple pin and carter pin thru the 2"into a plate with a hole.. As soon as I find some spring pins I'll replace those. 4"box tube base with 2" for the swing outs. Its made to hold up to a 33" tire. Not professional by any means but it suits me fine. I thought about liftinh the cooler basket higher for better clearence but I didn't want to have to open both sides to get in my lift gate back.
