av8rds
MAhole!
So I had to take my truck on the chassis dyno yesterday to tune out some detonation so I figured I'd share some results.
I attached the actual engine Dyno results from when it was built. Its a 393 with .060 over(398), AFR 185 heads, Edelbrock EFI upper/lower, and a custom cam(which I, at this point dont have the specs for but it was a TQ setup)
So the overview is at 3500 rpms its making 181ft/lbs and 122Hp at the wheels, at 3900 it jumps to 200HP(climbing to 230ish) and 270ftlbs(climbing to 291) of TQ. This is WAY down from the Engine Dyno sheet I attached. And the engine dyno shows a big TQ jump at 2400/2500rpm not up at 3900???
My tuner thought it was from the TQ converter locking up but I seem to remember it only locks up in 4th gear(Chevy 4l60e). I'm gonna have to look at the software and check as thats making a huge difference if thats the issue. Not that I really need any more TQ down low, I really dont.
So over all on the chassis dyno:
Max HP = 232@4239rpm/69.6mph
Max TQ = 291.4@4051/61.5mph
down from the engine dyno of:
Max HP = 381.7@4300rpm
Max TQ = 504.8@2900rpm
This is with the 398, 4L60e, Atlas 4sp, 4.88's and 36in Iroks.
