Pics of rocker trim clips
mlaird
Houston,TX
does anyone have pics of the original rocker trim clips? i need to find some clips so i can put the original trim back on and am having no luck at all
tinytim02
Sorry I can't help w/ any pictures of the original rocker trim clips. I've been searching for a set of rocker trim for my '72, but haven't had much luck....
Have you tried looking at the rocker trim clips for a 1973-1979 Ford F-Series? The style/width of the rocker trim on those trucks looks identical to the Bronco rocker trim. Both Auto Krafters and NPD (I'm sure there are others) make reproductions of the clips for the 73-79 F-series; they may work on the Bronco as well.
Hopefully someone has pics of some Bronco-specific clips. Good luck with your search.
pharmin06
I have a NOS set that ill try to dig out and gets pic's for you. And maybe they have part #s on them to cross reference
Joey
pharmin06
Here is a few pic's the plastic clips are curved and are held on with a rivet
Green76
Sherman, Texas
Where did you find these and what are the plastic looking straight (toothpick sized) pieces that are on the clips for?
behemoth
the tooth pic looking tabs are to keep the bolt on clip from turning while you tighten the nut on the other side. There is a close replacement for the plastic clips, I have some on my 72, it is not a ford part though it is for a Chrysler product. I will try and dig it up.
mlaird
mlaird
Houston,TX
that would be awesome behemoth. please let me know the chrysler part # or where to get them
thanks
eaglenest66
Very interested in the part number as well. Have a set of nos rocker trim but no clips either. Seems to be the common thing.
behemoth
mlaird
mlaird
Houston,TX
thanks so much behemoth. i already bought 10 of them. do they just screw in or are there any kinds of tricks to mounting them
behemoth
i just used a small screw into the old rivet hole. Some originals on my truck we actually screwed on as well, probably a earlier repair.
Bill
behemoth
Any luck with these parts ? I have them on mine now and appear to be working just fine. Just checking in to see what success or otherwise that others have had.
mlaird
mlaird
Houston,TX
mine work great and i forwarded this thread to another person with the same problem and his are working too. i will say that the trim is a little loose, but it hasnt fallen off.
behemoth
The front and rear clips have the nuts on them and mine was loose as well until I tightened them up. I also purchased new ones of those to eliminate the chance of it falling off. Good to hear they are working for us.
eaglenest66
Measurements
Can anyone who has the original clips for the rocker trim tell me the overall dimensions as well as the part number? thanks, tim
