broncodriver99
Ready to sell my '69. Gotta let her go so I can finish my '73 build. Picked this up a few months ago and have been tinkering with it. New voltage regulator and alternator harness, rebuilt carb., converted to Petronix electronic ignition, new plugs, cap and rotor, filters, etc. All fluids changed. New M/C brake lines and brakes bled until they ran clean fluid.
117,000 miles
Feb. '69 Build Date
Uncut/Unmolested California Truck
Original Paint (Med. Aqua)
Manual Steering
D30 Drum Brakes
302 3 Speed on the column
Factory Front Bench and Bulkhead
Original Vinyl Floor Mat
Matchstick and Corinthian Interior
4.11:1 Factory Rears
San Jose DSO
There is very little rust in this truck. Mostly surface rust. The Drivers floorboard is just starting to show pinholes at the seam, the passengers has a little rust but is solid. The only other rust I found is in the bed at the rear of the bulkhead. There is a thin strip where the two meet that has rusted through. Should be easy to fix. The door posts and strikers are perfect. Doors open and close perfectly. Everything on this truck works. The wiring is in excellent condition. Engine runs great. And Brakes stop well.
It has a pretty good dent right behind the drivers door and it looks like someone checked a chain link fence with the passengers side front corner. The only thing it needs is a heater valve. The one in it is seized. The armrests are missing as well.
Looking to get $6000 for her. Have more than that in her.
117,000 miles
Feb. '69 Build Date
Manual Steering
D30 Drum Brakes
San Jose DSO
