Pretty sure it ended because he has them in correctly. It's correct "for his springs".
We saw no double-eye, so there was no need to change.
What springs do you have? And what is your problem? Bottom line is that, if you have a double-wrap (aka Military double-wrap) eye at either end, that always goes directly to the spring hanger in the front. The shackle end would get the single wrap, no matter what other characteristics that eye has.
The image 70_Steve put up shows the correct orientation of a stock spring. And even though you have to look closely, you can see the slight variation in the two eyes, and which direction the shackles are supposed to face.
That help?
