Vragor
Since my recent rebuild, I've been chasing my timing a bit.
Truck runs fine and then suddenly seems to be miss-timed. Things like missing a lot, a loud chug as I'm trying to accelerate from a stop, or even a real backfire on decelerate.
Timing light usually shows the timing out. Generally retarded a bit.
I'm running a Duraspark II which can only move 20 or 30 degrees before hitting something, so I can tell by physical proximity whether the distributor has actually changed position or not, and it doesn't seem to be.
I mentioned this to someone at a recent meet and greet and he asked what kind of shape my harmonic balancer was in, and its in bad shape. Lots of cracks in the rubber ring, and even bits protruding. When its idling I can see a slight wobble to the outer ring.
Yesterday I pulled the distributor out to see if the gear was wearing or any other obvious problem, but all looked fine. The gear is on with pins all the way through the shaft, so no possibility of a loose set screw and a slipping gear.
When I put it all back together and re-timed it, it was running terrible. I advanced the distributor until it was running smooth and checked the timing again and it looks like I'm way advanced. I can't see the TDC mark at all, and the mark for normal timing barely visible under the water pump.
Is this conclusive proof that I need a new harmonic balancer? How would the balancer shifting make my truck run worse if the distributor hasn't changed?
