Mars Chariot 2.0: 1971 Off-the-Frame Re-Rebuild, *UPDATE* 6/16/12 IT'S ALIVE!!!!
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
Now that the ’71 Bronco (MarsChariot) is more than halfway through its off-the-frame re-build, I can safely start a build thread to document the rebuild, which I refer to as the “re - rebuild” as will be explained later. And I can now talk about it since I have been unable to talk about it for two years because it was just too painful to think about out loud.
Three year ago, on August 13, 2007 I had just completed my year long EFI and 5.0 GT-40 crate motor installation and took a few pictures. A few hours later I had a garage fire (started by an air compressor that was plugged in but not turned on). The flames engulfed the interior of the garage where both the wife’s Blue ’73 and my Red ’71 were at the time. The blue ’73 burned substantially because the fire started right next to it, but even the ’71 got cooked and smoke-“plated” while the contents of the garage burned and exploded all around it.
I had the hood up after admiring the results of all my labors, so during the fire the engine was exposed to the oven-like radiant heat all around it and the new engine was instantly made to look like it was 40 years old. Every bit of plastic was melted, wires burned, and polished aluminum dulled and “powder-coated” with soot, oil, and smoke. Higher up on the roof, the paint was blistered and burned from the heat. All exposed polished metal was instantly 20 years old, like it was from the rust belt and completely oxidized, rusted, or corroded.
The timing of the fire, just a few hours after finishing a year-long rebuild and conversion, and without even getting to crank it, was a bit over the top in my opinion. It pissed me off so much that I vowed to return the Chariot to better than before just to shake my fist at the fates. Of such are deep psychoses made.
During the next few months the garage was rebuilt with improvements, including a freakin’ overhead sprinkler system. (No electrical devices are left plugged in anymore. This is what the firemen are always saying, but nobody listens to them. So go out in your garage and unplugged anything that does not need to be plugged in right now.)
Because the Chariot had been pretty much restored before (See the ClassicBronco Calendar, October 2006), this has been a slightly different off-the-frame restoration. It is essentially a job of “remove, clean, polish, paint or replace” instead of the usual time-consuming build-up and fabrication of most re-builds. I did it all once already over the past couple of decades. Now all I had to do was do it again, but quicker and better. Hence the “MarsChariot 2.0” title. So the body came off and went to a local restoration shop, the frame stayed and got a thorough re-furbishment, and they both just came together last fall. I recently completed the Painless harness install, which is the occasion of my ability to breath a sigh of relief. There are lots of things to do yet, but this marked the halfway point.
Moral of the story: Broncos are nearly immortal. Everything in the garage was toast, but the Chariot held up and rolled out, just in need of serious (off-the-frame) re-finishing to remove the black powder coating it acquired during the fire.
Below are the before the fire and after the fire pictures. The next update will show progress on the body and the frame.
Before the fire (first three pictures) and after the fire (ast five pictures).:
garberz
Bronco Influencer
Conejo Valley, Ca.
I've seen those pics of your engine bay before. You really did a nice job on the EFI and crate motor. I had no idea about the fire. Those pics are very sad.:cry: Now that your talking about it, hopefully things will be better. I'll be following your build. :)
bowhunter
Sorry to hear this story!
That is an awesome ride! I love everything about it.
904Bronco
San Martin, CA
This is truely a sad story :cry: All that work... But Glad to hear that you are moving forward and I wish you continued sucess with the new/old build...
And make sure there are many pictures... You know what pictures whores we are... ;D
I have been to a few garage fires in my time, the most exciting was the one where the owner had his reloading and ammo stored! Anything that does not need to be plugged in should not be...
MarsChariot
MarsChariot
Planetary Offroader
Mars Chariot 2.0: 1971 Off-the-Frame Re-Rebuild Thread-2
Well, we rebuilt the garage to better than it was and replaced the blue ’73 with Zanes “Twilight” Bronco. In the mean time the ’71 was clean as best it could be be to get rid of the soot and debris. Then once the garage was ready it came back and I parked it on a couple of layers of plastic to protect the new garage floor, and proceeded to dismantle it. The plan was the strip it down to a body on a frame. Ship it to Mild to Wild to remove the body and start body refinishing. While that was happening the frame would come back to my garage where I would handle the frame end of things.
Below are a couple of picture taken during the disassembly process.
The first picture shows how the paint blistered, in the process revealing some body filler that it acquired in the first 6 years of its life. This fender would ultimately be replaced with a new fender from Tom’s.
The second picture shows a little bit of the fire’s intensity. Notice the side marker completely bubbled! But then this was the side facing the flaming ’73.
The third picture shows the headliner. Now the interior was basically untouched by flame, but got steamed and baked. The roof was up in the upper part of the garage where the heat was so intense that the roof paint bubbles. Even though I had some foam rubber under the headliner, the heat baked and peeled the headliner.
The fourth picture shows that the glue holding the foam rubber basically burned. The foam rubber turned to powder in many places.
The fifth picture shows that the interior was essentially intact. This means that even though there was a hell storm going on outside the Bronco, the interior remained untouched by flames and only a part of the soot got in. The seat upholstery was untouched, but need a good cleaning. Regardless, the interior was stripped and most of the items are going to be replaced.
During the tear down, some items got cleaned and refurbished right away, like the wiper mechanism. During the fire this assembly was made to look like it had been sitting in a field for 30 years. Bright and shiny. The first restoration item. Note my nice, clean new garage work bench!
The next update will show progress on getting the body re-done.
NY-Bronco
Resident Dipstick
Weehawken, NJ
Wow, I dont know how I would react if my EB caught fire. Really sorry to hear/see that. The EB survived remarkably wee considering it was up in flames. I look forward to seeing what youre going to do next.
Ohio Bronco 21
Cleveland
I would have been pretty sick If I lost my garage and Broncos. Im glad your back on the road to a really nice Bronco. You do fine work.
MarsChariot
MarsChariot
Planetary Offroader
I almost forgot. Just for the record, here is what the wife's '73 looked like after it was pulled out of the garage. You can see the smoke marks above the garage door from where the '73 burned. All because of a stupid Sears air compressor.
ponypower took this project over and is currently bringing this back to life, and we hope to see the result someday soon. He does awesome work bringing Bronco pieces back to life.
Hmmm, for somereason the image files did not "take"., I'll try again.
MarsChariot
MarsChariot
Planetary Offroader
(O.k. one more try before I go off and find out what the issue is. File sizes seem o.k.)
Look's like it's working. The last image is the before image from this year's calendar.
englewoodcowboy
Lick Creek Restorations
What a bummer but glad your pushing forward... funny thing is I am certain you will find things you want to change from what you had and now you have an excuse to do it. Good luck to you and hope they turn out just as you want them too.
ponypower77
The 73 is starting to come together and I plan to have it at next years meet and greet.
NCSUWoj
Lynchburg, VA
Just walked outside and unplugged my compressor! (and everything else that was plugged up in the garage that didn't need to be!!!) Terribly sorry to hear/see the carnage. I know all too well about bronco's and fires. Unfortunately I wrecked mine with 2k miles on a fresh rebuilt motor and the whole thing went up in flames:-[
MarsChariot
MarsChariot
Planetary Offroader
Hey Wes, we still owe you a visit. Besides we want to see the progress and hear the good and the bad! At that rate, you will beat me. The Chariot is in a dollar slump. But who knows.
MarsChariot
MarsChariot
Planetary Offroader
Mars Chariot 2.0: 1971 Off-the-Frame Re-Rebuild Thread – 3
After the Chariot came back to the newly rebuilt garage and the tear-down commenced, it was basically just a matter of wrenching and removing EVERTHING. My goal was to strip off everything that could be removed and send it out to have the body removed and worked on and the frame would come back. Some of the take-offs got restored, like the wiper mechanism as in the last post, other things for which there is a good replacement got replaced.
I bought a coupe of boxes of large Zip-Lok bags to store each part as removed. As I removed things I carefully labeled it. This includes the smallest screw or washer, a fact that really saved a lot of headaches, even if I did not reused the particular part since having the old part helped me find a new one or a substitute. Amazingly, with the exception of seats, dash, column, steering wheel, etc, most of the parts from a Bronco will fit in a large Zip-Lok bag. Door panels, interior trim, headliner went into the trash. And the sum total of all parts fit mostly inside two 18x18x18 U-Haul type boxes. Items deemed restorable were the rear light assemblies, which got a detailed restoration, as did the headlight buckets. New front turn signals and side marker assemblies were ordered along with new Solex glass from Duffs, new exterior trim and rubber seals of every description from Dennis Carpenter along with a couple of $Ks worth of their other goodies. The parts list is several pages long.
Once it was stripped pretty well, the whole thing was flat-bedded to Mild to Wild, a local custom vehicle builder, for the bodywork. Once the body was removed and soda blasted it was placed on a rolling Bronco frame (not mine) that they had on hand. We decided to replace the front grill, the drivers front fender, and the tailgate with new reproductions rather than waste shop time trying to get them straight. Panels all mostly from Tom’s.
Below are the pictures
First picture: Stripped, loaded up, and ready to go the shop. The glass will be removed and replaced at the shop.You can see some of the many paint splatters on the windshield. These occurred as the paint cans on the shelves in the garage started exploding during the fire. I ended up with a nice Jackson Pollack type paint job.
Second: Arrival at the shop. Note the Pantera, which indicates something of the clientele. Funny thing is, while we were putting the Bronco in the shop, the Pantera was driven in and replaced with a black Ford GT. The GT was there for some work on the oil pan. Seems the Ford dealer messed it up, and the only shop that they trusted to get it right was Mild to Wild.
Third: One week later the body and top had been removed and the tub soda blasted to bare metal. Again the frame is from another Bronco and was used at this stage as a buck for panel fitting, and for purposes of rolling the body around the shop during various stages of the heavy body work. I believe those are 11.50x32s on 8 inch rims and probably 3 inches of lift. Clears the uncut fenders. But I don’t need to worry about it since I have 3 inches of lift but no 32s.
Fourth: Good view from the rear. No rust on the tailgate area of the bed since that is galvanized metal. After years of water seeping past the lift gate lower seal, I expected some rust. But it is solid metal there. Soda blasting certainly reveals everything.
Fifth: Panel straightening and an old CB antenna hole gets filled.
Sixth: Floors. Some rust from a one-time leaking heater core that soaked the floor. This floor gets replaced with new metal from the Gaveyard. Otherwise the interior looks good o this side.
Seventh: Another view of the passenger floor.
Eighth: Driver’s side floor. Some more floor rust. Otherwise no rust. All the other brownish areas are just seams where all the red paint did not get removed. This floor gets replaced with new metal, too.
The top and doors got the same treatment .
MarsChariot
MarsChariot
Planetary Offroader
And one more..
Uh oh. Yes, the usual kick panel metal rust shows up with a good blast. Otherwise, no rust in sight This panel gets replacement, too.
