DanWheeler
EDIT 4/11/202 - I've recently fixed all the pic links.
Also, if you need a larger master cylinder due to large tires, check out my 1.5" Ford F350 MC and hboost thread titled:
"Dan Wheeler's One-Ton 1.5" Bore Master Cylinder and Hydroboost Thread"
(it won't allow me to link to it here so you'll have to search for it)
Recently, I've had several people ask me about my hydroboost setup and I noticed my old astroboost thread is outdated so I'm starting this new one with updated pics, info and part numbers. It's not the end-all/be-all hydroboost thread, just how I did it. The part numbers are from www.SummitRacing.com
Big Parts:
- 1 junkyard hydroboost unit from an Astro/Safari van
- 1 junkyard master cylinder from an Astro/Safari van
- 1 extra large brake fluid reservoir from the other Astro/Safari van in the same row
- 1 4x4x2 steering gearbox from eBay (78/79 Bronco case w/ F150 internals)
I want my pressure lines to be -6 AN. I use the Russell Powerflex braided stainless steel hose which is specifically designed for power steering. Do not use any pressure lines or fittings that are not rated for power steering/hydraulic.
Inputs/Outputs:
- Hydroboost input = M16x1.5 bubble flare
- Hydroboost output = M18x1.5 bubble flare
- 4x4x2 Steering Box input = 5/8-18 inverted flare
- Saginaw "Canned Ham" P/S pump can be either 3/8ths inverted flare or M16x1.5 bubble flare
- Explorer P/S pump is proprietary/weird. You can get the -6AN fitting you need from https://leepowersteering.com/collec...-with-seat-ford-pumps-racks-pinions-16mm-to-6 for about $20.
Explorer P/S pump -6AN fitting from Lee Power Steering (aluminum washer is upside-down in this pic)
Fittings/Parts:
You will need (2) different bubble flare to -6AN fittings for the hydroboost unit:
- RUS-648060 Fitting, Straight, AN Flare to Metric, Stainless Steel, -6 AN to 16mm x 1.5 Male
- RUS-648080 Fitting, Straight, AN Flare to Metric, Steel, -6 AN to 18mm x 1.5 O-Ring
If you have the Saginaw canned ham pump, you will need (2) of the above RUS-648060 fittings. If you have an older Saginaw canned ham pump with 3/8ths inverted flare, you'll need a -6AN conversion fitting for that (sorry no part number)
If you have the 4x4x2 box you will need a -6 AN to 5/8-18 NPT fitting:
- RUS-640380 Fitting, Straight, -6 AN Male to 5/8-18 in. Inverted Flare, Steel, Zinc, Each
you may also need a fitting for the steering box low pressure return which I believe is 3/8ths inverted flare. You can buy a little piece of pre-flared hard line from NAPA with fittings for this.
You will need some power steering hose:
RUS-632620 Hose, Powerflex, Braided Stainless Steel, -6 AN, 10 ft.
You will need hose ends. I used (4) 90 degree bend hose ends:
RUS-620421 Fitting, Hose End, Power Steering, 90 Degree, -6 AN Hose to Female -6 AN
You will want a brake proportioning valve to adjust the front/back bias:
http://www.summitracing.com/parts/SUM-G3905/
Don't use the Astro van valve - its not worth it. The chances of the Astro van front/rear bias being the same as your Bronco are slim to none. Buy a proportioning valve and take it out to a parking lot and adjust until you have it set right so front/rear lock up equally.
You may want to pick up a power steering cooler:
PRM-1007 Perma-Cool Compact Fluid Coolers Fluid Cooler
the rest of the parts needed, you should be able to pick up locally.
Putting It Together:
Some of these pictures may be confusing because they are a mix of pre and post Explorer 5.0 install. The basics are the same.
I chose to modify the astroboost bracket to use the existing Bronco master cylinder holes. I had to chop the corner to make room for one of the bolts on the firewall
You will need to open up the hole in the firewall a bit so the nut on the hydroboost bracket fits inside.
You can mount the hydroboost in any orientation. Whatever works. This can get very complicated with EFI because of the upper intake. Having a body lift also changes things. Angle brackets are available that point the hydroboost and master cylinder towards the driver's side to make room for the upper intake.
In my case, when I went EFI, I was strongly opposed to using an angle bracket so I flipped my upper intake and did some customization to the Explorer 5.0 elbow so it would all fit: (just barely)
here is a picture of the final product with my 302 and canned ham pump:
you will need to cut, thread and "splice" your astro/bronco pushrods together:
Use a long coupler, lock nuts, thread lock... Whatever it takes for those 2 pieces to never come apart.
here is looking at the back of the canned ham pump:
and from the bottom of the steering box:
The bracket installed on the firewall. Use the existing MC bolts just drill new holes on the plate. (not the corner cut to clear the screw)
the brake prop valve:
replacing the small rear drum brake reservoir with a large one. This is a great mod if your rear cylinders leak. Just pop the small one off and put the large one on.
hard to see, but you can get an idea of the routing on the Explorer 5.0
use a brass Tee for the return lines and put the Tee as close as possible to the reservoir.
here is a routing diagram:
Once you get everything connected, put the front end up on jacks and turn the steering lock to lock while pressing the brakes 700 times. Maybe more
make sure you keep the reservoir full so it doesn't suck more air making things worse.
Big Parts:
Inputs/Outputs:
Fittings/Parts:
