1" BL,, so easy a girl could do it,, hehehee
;D,, well I'm trying.
I've been installing a 1"BL from WH and I loosened the fan shroud and let it flop, disconnected the clutch rod, removed the heart shaped steering support bracket, (it was attached the firewall and clamped to the steering column shaft. Took out the battery,& tray, and removed the horn so I could see the front bolts,, removed the drivers seat ( the passenger seat would flip forward).
I started removing my body mounts last Saturday Oct 26th. About 2 hours on Saturday, 3 hrs on Sunday, 2 1/2 hrs on Monday and 2 hours Tuesday. Took me that long to just get them out. I know,, I know Grandma was slow but she was old,,.
I started on the drivers side left rear as a test,, soon as I touched the bolt head with the socket and it popped off. Had to sawsall the cr@p out of that one. I just didn't have any idea what I was trying to take apart or how it came apart so I was just hacking at it, beating on it whatever. I was thinking how did they come up with such a devious way of connecting together.
Then went to the right rear and down the passenger side. Got all those bolts out using the " loosen a little bit, tighten a little bit method" with liberal amounts of PB blaster. Wore my arm out.
The mounts still would not come out. Had go back and read up some more on what I was missing. The key was run the bolt back in a few turns and wail on it with a BFH. Worked like a charm and all the mounts came apart. I jacked the passenger side up ( floor jack, 3 ft 4x4 under the door / body rocker on the flat part) and removed all the rubber mounts with flat bar and pliers. (put the tires back on the opposite side I was jacking up just for extra added safety)
So to the drivers side,,,,,,,left rear was already out.... Then went to the one behind the driver’s seat. It came out using the “loosen a little bit, tighten a little bit method" but it took forever. I listened to that bolt cry for help a long time. I said this is not good. Drivers side floor pan bolt head was rounded off. I’m not sure if someone had tried previously and did that? I couldn't get a socket or wrench anything to grip it. I go to the drivers’ side front. “Loosen a little bit, tighten a little bit method" work until the very end then the rubber mount started spinning. That was new. I reach for BFH and wailed on it (had to use a long chisel) and the mount came apart enough I was able to get the vise grips on it and finished loosening it.
So that left drivers side floor pan. I'm not screwing around on this one,,,, no mercy as I didn’t have any more “be calm take deep breathe” in me. I went straight for the sawsall. By the way no one ever mentions the stinking burnt rubber smell,, it was so bad I had to get a fan blowing on it. So covered in dirt and grease,, smelling like burnt rubber, PB blaster, WD-40, 2 bent saw blades, and some curse words the bolt and mount gave up.
So the bolts and the mounts are out on the passenger side and all the bolts are loosen on the drivers side. (the mounts are still in) and I took 2 of the bolts and cleaned the up and put them back in so the body would not be totally free to move around. Then I got the new mounts in on the passenger side but it took me a while. Just slow I guess. I was looking for the notorious "nut swallowing hole" on the mount behind the passenger side seat but I could not find it? I'll look for it on the drivers side when I start installing those mounts, and I have my tape ready.
I read every thread I could on body lifts here about 5 times... I had extra coaching from a few people using PMs and the extra feedback was appreciated. I got some help from Jim Beam too,,(after I was finished last night). He said I was doing a good job,, slow as hell,,,,, but ok. %)
This is just my exprience so far and is not a fair representation of how long this takes. Do the reading on the other threads,,, and you will probably see every possible scenario.
No I'm not done yet,, as I still have to get the drivers side mounts in and then put all the other stuff back together. Then I hope to earn my Bronco body lift installation badge,,,
