1972 Rust Repair
Was this helpful?
  • Yes!
    Votes: 5 100.0%
  • No.
    Votes: 0 0.0%
  • Total voters
    5
Bay0726
Woodstock GA
1972 Bronco Sport restoration project
Bay0726
Bay0726
Woodstock GA
Plan on fixing the rust to start, then I would like to paint it and lift it. Thinking 3.5 susp. and already have the wh 1" body lift...
Bay0726
Bay0726
Woodstock GA
Here is some starters for the rust repair
Bay0726
Bay0726
Woodstock GA
More rust ... !
Bay0726
Bay0726
Woodstock GA
Rocker fitment
Checking the fit on the rocker and getting ready to cut out the quarter panel. I found a folgers coffee can used to repair the rust... Good to the last drop!
Bay0726
Bay0726
Woodstock GA
Rear Quarter cuto out
Ouch, this hurt... The point of no return! Found out someone had tried to repair a dent! by laying another quarter skin over the dented one causing rust...
Bay0726
Bay0726
Woodstock GA
patch panel
Made a patch for the upper quarter, the metal was swelled and rusted where the upper and lower quarter meet
Bay0726
Bay0726
Woodstock GA
fitting the new quarter skin
Here she goes, it was hard to fit at the top and the back, but overall fit was pretty good for aftermarket parts. I just took my time and kept working the panel a little more and a little more into place.
Bay0726
Bay0726
Woodstock GA
More shots of the quarter
I started welding from the top, went to the rear and last did the door post. Then moved to the rocker. Rather then welding upside down, I drilled holes in the upper quarter and welded it to the lower quarter. Went through the wheel well to the tail light cap and the door jamb was easy.
Bay0726
Bay0726
Woodstock GA
Rocker
The Rocker was a pain in the A**! I had to section it, bend it beat it floor jack it and beat it some more to get it to fit into place. The door gap to the rocker was almost 2 inches when I started, not its about 1/2 to 3/4
Bay0726
Bay0726
Woodstock GA
Some other toys,
Well thats it next is the pass side
Thanks for looking guys!
Hank_
Nice job on the work. Its funny how these broncos rust in the same areas. I am in the process of working on mine. The pictures will be helpful. Thanks for sharing.
Henry
NGABronco
Always Learning
N. GA now South Carolina
Yeah, Bay came by the house today!!! It's funny seeing an EB cut on one side and uncut on the other!!!!%)%)%)
I told him he could start a new fad!!!!!:cool::cool::cool: Great work, that ole rig is pretty solid except for the outer panels, kinda strange how it rusted.;D;D
Now get back to work Bernie!!!!!;D;D;D
Bay0726
Bay0726
Woodstock GA
Henry
Thanks Henry, You Bet! I'll be posting more soon.
Bernie
Bay0726
Bay0726
Woodstock GA
Im m a going . . .
Bay0726
Bay0726
Woodstock GA
Nice work :) Did you use a sealer at all on the quarter panel? I was curious if you do this or not when replacing the panel.
I will use 3m seam sealer on all the welds, and joints after everything is done. Especially all the ones Ford missed, Thats probably why it rusted!
