Its My Official Build Thread (new pic 06 nov2014)
fordguy
no name yet, but i did get the tub back from the acid dip and left the frame. i have turned around and headed the other way after hitting rock bottom. here is the tub pics. will start ordering metal next week.
half cab
Guru Bronco
Looking good there keep them pic's comin when you can;D
Gene
F
fordguy
750.00 dollars. as far as i can tell the acid is nuetralized. i will replace the metal that needs it and it will go back for de-rust and ecoat. ecoat is a dipped exopy they use on new cars. frame is getting dipped now and should be back in several weeks, it is also being ecoated. cant decide on what to do for paint on the frame, will try to figure that out next week. they have all kinds of cool powder coat colors.
F
fordguy
yeah sorta good thing bad thing. no problem finding the spot welds;D
F
fordguy
conpany in jackson called metal finishing services. we also have a local nissan plant and a sub for them does ecoating and metal finishing has a deal worked out with them
F
fordguy
got a couple of hours work in yesterday, everything is looking good. hope to get passenger pan in this week.
F
fordguy
cold chisel and side grinder has been working for me to get the floor pan off the braces. spot weld remover does ok in some places. slow going, will probably order the rotisserie. frame has gone to ecoat so it should be back next week, that will give me something to work on when i get bored with sheet metal removal.;D
F
fordguy
took some all thread and used it as a tensioner and pulled the gap tight on my tail light housing. the original spare tire rack had it stretched out about a 1/4 of inch. have the passenger floor pan fitted, ready to weld. running buddy is coming by tomorrow to inspect.
F
fordguy
slow going on the floor plans, frame will be back next week, so i can work on that when i get bored with cutting sheet metal. has anyone every rebuilt just the bottom of the front door posts/pillars. about 4 inches of mine is all that is bad. i was going to fab the bottoms up, but i cant really tell how it is made. does someone have some not on the truck they could take some close-ups of the bottom.
F
fordguy
frame got delayed in ecoat, will pick it up tomorrow and post pics of how the ecoat looks.
Stutsmo
I wanna see the pics of the ecoated frame. Is the tub going to get Ecoated also?
They Ecoat RV frames where my brother works and depending on how yours turns out I might check out getting mine done also.
F
fordguy
here are some pics
