    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
TX UPDATED:Holley carb and fuel pump, stock dash/knobs, misc interior/exterior parts
Status
Not open for further replies.
backpain
UPDATED 11/18/11, sold items removed from listing. See pictures following throughout the thread below.
Local pick up gets priority. I just don't have time for shipping on most of this. Any S&H at buyers expense. No offers including shipping, because then I have to figure out how much it will cost to evaluate your offer. Again, the lack of time thing causing the problem . . . .
Engine and related:
OFFER -rebuilt 302 short block (mid 80's truck block casting); good runner, no probs on highway at 70mph or around town before I took it out; pick up only; free engine stand bolted to it!
OFFER -cast aluminum Ford valve covers; finned and embossed lettered tops (see pictures below), peeling chrome needs to be stripped, then refinish to your liking; same as the $120-200 version with different logo
50.00 -NEW Holley mechanical fuel pump, 80gph, polished, never used (sending back to Summit, less restock fee if no one wants it)
175.00 -Holley carb; 600CFM, elec choke; almost new, Ford AT w/kickdown bracket
15.00 -kickdown rod
15.00 -3 groove, 3 bolt crank pulley
25.00 -stock PS pump ('75) with pulley and brackets
25.00 -stock type 60A alternator converted to 2 wire/onboard regulator
20.00 -V belt alt pulley; March; polished with cover ($45 new)
5.00 -2 pc alt brackets; stock type - steel
10.00 -2 pc alt brackets; stock type - chrome
Dash related:
75.00 -stock dash panel w/single DIN radio cutout
50.00 -stock speedo/cluster; everything worked when removed - gauges and indicators
5.00 -stock speedo cable (used in stock cluster and auto trans/transfer case); free with purchase of gauge cluster
30.00 -Autometer Ultra-Lite fuel gauge - NEW/never used, for stock EB sender; electric; alum trim ring, silver face; $45 new; (sending back to Summit, less restock fee if no one wants it)
10.00 -Sunpro tachometer; 3" (approx) column mount
offer -plastic column bezel; stock type, sanded smooth for repainting
Other interior:
25.00 -NEW Billet Specialties round in-dash vents ($23 ea new) w/polished billet alum bezels - never used (currently packaged and ship'able to you 1lb, 1oz); (sending back to Summit, less restock fee if no one wants it)
offer -NEW Vintage Air chrome drier; never used - still sealed; with bracket; vertical mount ($70 new)
10.00 - rear bed carpet hold down trim piece; polished
offer - front/rear seat belts; not sure of vintage (may not be factory - see picture of fronts); black/blue (faded black webbing)
cheap - rectangular transfer case shifter boot/chrome bezel (fair condition)
Body/exterior/other:
25.00 -stock hood latch system, 3pc - latch that bolts to core support, pin and safety catch/release; used, good condition, no rust
75.00 -4x alum rims; aftermarket; 15" x 9.5"; 3.5" BS - hard to find; 80's style swirl 3 hole; good beaters, no spacers required; pick up only (see the single wheel picture)
door parts:
window regulators
window tracks
interior door panels
glass
stock hinges
locks
almost everything but the shells . . .
cheap -aftermarket coolant overflow tank (good condition, but inexpensive)
cheap -stock brake (drum/drum) distribution block (fair condition)
offer -butchered '75 wiring harness with many of the connectors, fuse block, etc
10 - 6-blade 18" rigid fan
offer -fuel selector valve
5 -fuel expansion tank cover plate
offer -floor dimmer switch
$45 - Lizard Skin Superpro spray gun kit ($80 new); used only for one complete application
misc other: jack hold down/bracket, 2 pc. overflow tank hold down/bracket(needs to be re-riveted or use bolts), distributor hold down, 1 or 2 lower dash brackets, a couple fender braces, misc odds and ends on death row for just a bit longer . . .
feel free to ask about anything else in the pictures
terms disclaimer: cash, as is, where is, but happy to discuss alternatives; best offer as determined by me always wins
may be willing to consider interesting trades - see post #17 for ideas. Local pick-up - will trade parts for beer!
B
backpain
some pics
B
backpain
more pics
B
backpain
front seat belts, misc stuff, bumper pics (the lights do not come with; the rear receiver you see is frame mounted; {clarification: receiver is just below the bumper on the frame, not part of the bumper})
B
backpain
Can you say, "rat's nest?" Here's a partially labeled, semi butchered wiring harness with most of the connectors still attached.
mattt
How many of the billet specialties vents do you have? I'm interested.`
mp
Austin, TX
75.00 -extra blank dash panel ($170 new BCB; partially assembled)
65.00 -stock AT steering column ('75); w/harness, rag joint flange, firewall seal; just needs a shot of paint; turn signal canceler needs replacement; all else worked when removed; currently pick up only (I don't know how to ship this thing)
15.00 -stock ebrake pedal assbly
15.00 -battery tray (refinished)
Interested in this stuff. Can figure out how to get it up to Austin.
B
backpain
I may be coming up this weekend :). If not someone I know will be if you want to make it over to Barton Springs area. PM me and I'll send you a ph#
n59rob
Sweetwater, TN
A/C unit
I am interested in the AC unit but would have to have it shipped to 37874. Why is the compressor and drier not included? Did they not come with the unit originally? Let me know if you will ship. I have a sales rep in Houston that would likely ship it for me if needed. Just let me know.
Thanks,
Robert
B
backpain
. . .Why is the compressor and drier not included? Did they not come with the unit originally?
Thanks,
Robert
I bought two different kits and pieced together a hybrid system = about $2500 of parts, unfortunately. These are the parts I bought 2 of.
I can look into what it takes to get it all boxed up together. It came in a few different boxes. Hopefully late this wkend. PM me as a reminder (but I am out for a few days for the holiday)
techlaf
What is the size/width of that steering wheel? Does it come with the mounting kit/screws?
B
backpain
approx 12.65", which Grant probably calls 12.5 or 13". It comes with horn button and mounting screws. If I were using it, I'd buy their billet mounting kit to match the hub to the spokes. My local A-zone stocks them.
PM me if you want to discuss in detail or need more pictures.
B
backpain
. . for those interested in steering, I might be able to find the stock lower shaft also. I have to replace with custom because I moved the column position.
I'm sure it's at the shop somewhere
B
backpain
I guess I could create a random list of possible trade items. Here's stuff I need or wouldn't mind sitting around the garage. Trade, trade+$$, $$+trade - whatever:
- HD axles and differential (I have stock splined axles, with Strange ltd slip; some day will upgrade to more splines)
- I also have an extra set of stock radius arms w/caps; keeping until I make some extended ones or need them for core; would trade these and some other parts for some really good full articulating or extended ones
- I may need a Jeep seat (rear) fold and tumble latch or similar - to fab my passenger custom seat mount for forward tilt
- I need a Trailmax II fold and tumble back seat in black denim (or something that will similarly match my fronts
- tools - always willing to listen
- some really good front 6.5" speakers; coax or separates considered; grills also
- cheap old ipad, itouch or iphones (not to use as phone or media player, but simply as extra Apple TV remotes - wi-fi use only; must be able to take new apps)
- billet window cranks; unfinished/clear
- misc diamond plate interior trim/guards
- Super Shackles or similar HD part
- new weatherstripping
- extra Al radiator or Al shroud
- body labor (i.e. filling and sanding; must be a pro, or I'll do it - but I hate it)
-plate bumpers
-good winch (I am not rebuilding one)
- front wiper conversion (Cherokee or similar)
- 33" spare tire (for 15" wheel; can be used, but has to look good enough to go on a carrier - and of course work when needed)
- tranny and PS coolers
- rear disc parts
- shock hoops
- ram assist
- Hi-lift
- headliner and install
- AOD and/or conversion parts
- misc hi-po 351 or 427 parts
- LSx
- home appliance labor (calling out Broncow72 :) )
- '66 Galaxie convertible (ok, now I'm stretching for ideas)
- I have some rear 1/8" qrtr protectors - haven't yet decided if I will use
. . . more to be listed in this post as I come up with trade/wanted ideas
broncomatt
I'm interested in the drivers side fresh air box, how much to ship it to, 27020
B
backpain
whatever fedex or UPS tells u - I can have someone do either of those for me from 77007. PM me and I'll send you a ph# if u want to discuss
Status
