Are My Leaf Springs On Backwards?
BronCowie
Old Timer
Vancouver, WA
?:? A Bronco buddy told me he thinks they are on backwards... One is straight where it attaches to the frame and the other end has a slight downward curve to it. Which end is suppose to be on the forward end?
Pic 1 has the straight end on the rear, pic 2 has the curved end on the forward mount. ?:?
Stock springs, correct.
Nationals (with the double wrap) then it would be backwards.
Those look stock and correct.
dlong
Las Vegas
I noticed in the first pic that his hanger for the leaf has the open end facing fwd. Is this the normal position stock? Are they swapped the other way when a lift is installed? Just curious cause I noticed mine are flipped the other way and I have a 3.5" sl lift.
dieselbronco
Tolland CT
I think the shackles are correct. But it looks like the front spring bolt is loose with that rust trail, you should hit it with the impact gun before the hole opens up.
Nope, stock shackle goes open face rearward (away from the spring) with the closed end forward.
Completely counter-intuitive, but that's how they were.
And yes, they do act differently when put on the different ways. I always have a hard time remembering, but I think that, with them on backwards, they fold forward better but bind up with the spring under compression and vice versa for the other way 'round.
But don't quote me on that...
70_Steve
Old Guy
Pic courtesy of JBG.
BronCowie
BronCowie
Old Timer
Vancouver, WA
Thank you all for the feedback. All considered, it appears I have stock springs mounted correctly and my buddy was looking at aftermarket springs which appeared backwards, but perhaps they are not. We'll have to find out what kind of springs he has and revisit that.
The JBG drawing looks accurate; that would be the driver's side view, whereas my photos are of the passenger side, and they match.
The LMC drawing seems a bit generic where it doesn't show that curve in front of the front mounting hole.
FWIW I have a 2" lift.
70_Steve
Old Guy
Looks like the springs match the drawing, but, as was mentioned, it looks like your shackles are on backwards.
