Project 74-7 - *Topless* Last pics before owner comes picks her up
BlazinCopper
Jackson, TN
;)Well time to start building another bronco. I'm doing a transplant or body swap. Luber to a Shuber. I've found a home for my uncut body. I'm really relieved that I'm not going to cut it. I'm taking a 74 body - turning it into a 77. Removing the sidemarkers, and painting it my DeVille Bronco Green. This is a customer build and all modifications will have to be approved first, so I don't have all the finishing details yet. I'll keep ya'll posted.
half cab
Guru Bronco
COOL, will be looking on.Say you ain't all that far away.
HC
BlazinCopper
BlazinCopper
Jackson, TN
old body removed , frame cleaned and almost ready to paint. I have to repair a couple rust spots first.
BlazinCopper
BlazinCopper
Jackson, TN
I finished cleaning the frame and soaked it with a rust inhibitor - got that finished and then painted the frame with a enamel based farm equipment gloss black.
mattyq17
Frame is looking good, do you have any pictures of how you fixed that hole in the frame?
BlazinCopper
BlazinCopper
Jackson, TN
We use 3x3 1/8" thick square tubing. We basically cut out a the rusted spot in a square or rectangle, then cut out the same size piece out of the tubing. Make sure you cut the replacement piece a little big and then slowly trim it to fit. The tighter the fit, the easier it will be to weld. If you are repairing the frame in a bend/curve - you might have to weld one end of the plate and then use a hammer to form it to frame.
The 3x3 tubing works really well if you have to remove a top piece or lower piece because it is the same width as the frame and it makes it easier to fit.
Hope this helps some - I"ll see if I took any good pics of it and post them later
BlazinCopper
BlazinCopper
Jackson, TN
Got the top off - the dash, wiring, and pedals out - Painted under the dash
-Cleaned, sanded, and painted under the hood/radiator support. I don't understand why it takes 2 or 3 days to get under the hood ready to paint :mad:
Sorry for the crappy pics, had to use the camera phone - I'll post some better ones later.
While I'm on the subject of under the hood, has anyone else ever experienced a really sloppy factory upper cowl seal. Where the cowl meets the firewall - it looks like they poured a ton of sealer on the seam and even dripped it on the front wheel well. I though a PO had done it, but I removed some of it and it was bare metal under it. Wierd :eek: Didn't know if anyone else had the same thing happen
BlazinCopper
BlazinCopper
Jackson, TN
About ready to paint- got the body moved onto the 77 frame. So she's setting low ;D. Hope to paint it Saturday. I attached a pic with the stripes taped on the body like we are going to paint on it. Believe me when I say I am tired of block sanding. I've riubbed on this truck so much I feel like I should have to marry her ;D%)
BlazinCopper
BlazinCopper
Jackson, TN
Got a couple things painted today - man I forgot how much I love this color
Stutsmo
While I'm on the subject of under the hood, has anyone else ever experienced a really sloppy factory upper cowl seal. Where the cowl meets the firewall - it looks like they poured a ton of sealer on the seam and even dripped it on the front wheel well. I though a PO had done it, but I removed some of it and it was bare metal under it. Wierd Didn't know if anyone else had the same thing happen
Sounds like my 67. I had more sealer on the lip between the firewall and cowl than I had metal!
The Hood ,Grille, and Tailgate look good I really like that color!
BlazinCopper
BlazinCopper
Jackson, TN
This truck even had sealer dripped on the fender well by the firewall
