http://tucson.craigslist.org/cto/2769505496.html
I have a 1972 Explorer with removable hard top for sale. This has been a fun project that is complete minus paint and minor details. Here's a list of some of what's done:
stock 302 with 86k original miles with headers, electronic ignition, rebuilt carb, new fuel pump, new plugs and wires, new battery, new water pump, radiator, Original 3 speed manual transmission, moved the shifter to the floor instead of on the column MUCH NICER to drive. New clutch kit, dropped the oil pan and checked bottom end (crank, rods, bearings) all look phenomenal and no wear. Motor runs very strong. Differentials were flushed and checked and are all good. Rear is 9" and Dana 44 on front. New wheel bearings and 4wheel drive works flawlessly. New fiberglass hood and steel front passenger fender, body is all straight just needs to be sanded and painted. 4" suspension lift, all new radius arm bushings, chevy disc brake conversion on front, drums on rear, new master cylinder and brake lines. New Flaming River double D steering shaft, Ford '75 2x4 power steering conversion, replaced rusted floors with new, covered rocker panels with chromed aluminum diamond plate, cut fenders with flares riveted on, (6) 17x9 ProComp simulated beadlock wheels on 35x12.50 BFG Baja Race Projects (4) tires have about 25% left on them the other (2) have at least 75% left. New full rubber floor kit from fire wall to tail gate, pipe bumpers rear has tire gate. New dash, whiper motor cover and head liner, new reupholstered frontseats, no rear seat, new glass in hard top, interior is painted charchol grey with black trim to match new seats. New door panels and hardware. Too much to list. I need this truck out to start next project. $9000 on Craigslist $8500 here. There's over $5k just in parts. Will consider delivering if local (Tucson/Phoenix surrounding areas). Serious buyers only please contact Colt at 520-360-36 nine nine
Pictures available
Pictures available
