Map light
half cab
Guru Bronco
Anybody got a good pic of the factory map light under the dash just by your right knee.I'm tryin to put mine back in factory local and need to see how it was because it been along time sence I had it hooked up.%)
thanks,hc
jsnouffer
It's not the best picture but the only one I have on my computer. I can get you a better picture this weekend if someone hasn't posted one by then.
half cab
half cab
Guru Bronco
Thanks for the pic.Is it just pushed through the hole or does it have a bracket there.I undone mine some 25 yrs ago and put a toggle switch there for something(it's been so long I forgot)
hc
jsnouffer
There is a bracket. Here are some pictures I found in another thread.
Sent from my iPhone 4S using Tapatalk
half cab
half cab
Guru Bronco
Hay great,Thats it and thanks again man I call myself doin a search,but did not find nothing.Thats what I was lookin for.;D
hc
.94 OR
I've had one in a box of parts for years. I couldn't figure out what it was for until now.
Adarcy
Original Dealer put this in
half cab
half cab
Guru Bronco
The factory map light is turned on when you turn on the overhead lamp in the wiper motor cover.The feed wire and bulb(no.1895)are the same as the instrument panel guage illumination,hi beam,turn signal,and radio.This is not on all models.Thanks to dirt donk awhile back that I rediscovered that I had one.I had pulled the bulb out yrs ago and stuffed it up behind the dash panel and over the yrs had mounted several other things under the edge of the dash and had completely forgot about it.You know you've had the same truck to long when you can't blame nothing on a P.O.;)
hc
half cab
half cab
Guru Bronco
Just wanted to add a couple shots of it there behind the guage cluster before I put the freash air duct back in;D
