Picture stories of what we are working on in the Shop.
fordfan
A few pictures of the beginning of the metal replacement of the tub of a '72 sport. The owner is doing his chassis restoration and probably getting a buddy of his to do the paint. We are doing the metal replacement;installing "patch panels" in the front floor pans, kick panels, inner fenders, fender wells, radiator support, new grill, new front fenders, and .......YES.......cutting the rear fenders for flares!:cool::cool:
NGABronco
N. GA now South Carolina
Hey fordfan, nothing like starting out with 1/2 of a good tub!!!! I sure hope the doors, ft. fenders and top are in good shape!!!%)%)%)
Now get back to work!!!;D;D;D
blamejane
It's gonna be awesome...I just know it. As always, lots of pic please!
fordfan
fordfan
Hey Val, I didn't post on your search thread for your '76.....probably because I was too "Spell Bound" to respond.. It was a miracle how it all worked out! So....I congratulate you here from East Alabama!!
ford man
Leesburg Ga
Looks like you got your work cut out :eek: Are you going to straitin out the rear or put new panals in?
fordfan
fordfan
So you think you might have a use for some old used quarter panel cut-outs ..huh! You know scrap price is still pretty high!!!
cdelano89
Reminds me of an old convertible mustang I worked on with my dad in highschool... Hope you love spot welding! ;)
DWALKER
You better beleave Bragg Interprize dont scrap on bronco parts
fordfan
fordfan
'72 Sport Body Repair
Removed a little more of the damaged sheetmetal and had the complete front clip attached for a while, but somehow we didn't get pics. All the sheetmetal will be fitted (with the fenders and grill all attached), before anything is welded into position. This project has sheet metal from numerous sources and ages, so most of it has to be massaged to fit.
This Bronco was never in much mud because the body X members are really clean.....the only dirt is the dirt daubers castles. This Bronco also has had a little "Air" time in it's past as evidence by the bent X member at the floor pan and the impression of the body mount.
fordfan
fordfan
Converting Electrical Power to HOT Air!
Both of our facilities share the same air compressor, and our old compressor was taxed pretty heavily when the small glass bead cabinet ran for a while. So, much of today was spent installing the new air compressor ie. 1 1/2" galvanized piping, and electrical. The new compressor runs nice and quiet and pumps lots of air. The small cabinet blaster can run now and the compressor spends more time off than it does running. The big Vapor Blast cabinet, depending on which nozzle is in the head, would probably use all of the new compressor's air. The big cabinet is powered by a 85 hp diesel Ingersol-Rand pump that puts out 185 cfm. The new compressor is a 10hp with a V-4 pump on a 120 gallon tank that pumps 45 cfm.
DWalker is getting the other pump which is a 7.5 hp Quincy on a 80 gallon tank.:cry::cry:
fordfan
fordfan
New Sheet Metal!
Tub is coming around. I found a screw up from the factory: The inside seat bracket on the passenger seat never had bolts welded in the crossmember. We made a bracket and fixed the screw up!
fordfan
fordfan
More pics of the progress!
DWALKER
Looking good Bud. Holler when you deliver it and I will help you unload it.
Got started on my rewireing Monday.Hope to be done with this project next week.
