1969 Ford Bronco with 3-spd and 302 V8. I have had this truck for a few years now. The following is a list of recent repairs/renovations/additions:
• New (rebuilt) Dana 44 front axle replaced the old Dana 30
• New clutch
• 4 barrel carb/manifold (500 CFM Edelbrock)
• Hedman Hedders with two into one Magnaflow muffler and custom built exhaust (Muffler Masters)
• 3 speed moved from column to floor shift
• New radiator, water pump, thermostat
• New alternator, battery, starter, starter solenoid
• New distributor with Pertronix ignition system
• Manual fuel pump replaced with electric fuel pump
• 32” BFG’s on Centerline mag wheels
• Front and rear suspension replaced to provide a 4” lift
• Custom roll cage built and installed by Tanner 4x4
• New seats and seat belts
• Recovered rear seat
• New drive shafts
• Power brakes (drum)
• New headlight wiring harness with light relay to allow for halogen lighting
• New oil pan with screw-in dipstick tube
• New high-volume oil pump
• Various engine dress up components added
• Various other odds and ends replaced as might be expected
The exterior is kind of rough with rust on the rocker panels and a few other small areas.
• New clutch
• New drive shafts
