Only had a few moments to eyeball it this eve. , it is not the freeze plug that can be easily seen.
It appears to come from right near/behind the engine mount.
Temp. gauge never read hot , very little steam while I was driving it , but I could smell it.Figured it to be a small pin hole leak. I had checked the fluids a day or two before. I had drove it quite a bit earlier in the day and had no issues. Drove it nice-n-easy home about 1.5 miles. 1/2 block away , it started smelling REAL hot , gauge still in normal area. Stopped it , unloaded daughter , popped hood , saw some water on the timing cover boiling (from tiny leak at intake fitting , had been there a awhile and had never been an issue , coolant loss was minimal) and knew she was HOTT!
Started up , slow cranking , but she fired and idled , added water to the rad. and the fun began , boiling , spewing , refill ,repeat , until motor cooled down.
I'm glad the motor was old and loose , otherwise it may have locked up on me.
I'm really curious as to what the cause is , either way , it is officially time to start the tear down and do the resto-mod phase 1 (everything south of the body mounts).
Machinist has my 347 at the shop , NV3550 is on the bench and has been cleaned and inspected by the local pro .... ready to go !
![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
