The AFB I'm currently running on a torque oriented 351 is hard to finesse in tight maneuvers. The driver is bouncing around and so is the right foot. A snappy responsive engine is good. but anything can be over done. On my Holley I moved the throttle ball about 3/4" further away from the throttle shaft. This worked but I can't do the same on the AFB. I was hoping the complex '69 linkage could help. A cable linkage won't do much to steady my right foot.
After having my fan eat the shroud when the motor mount separated, I replaced them with the type that have a steel rod to keep the mount together. The engine movement is small compared to driver-foot movement. Even a hydraulic accelerator linkage wouldn't help that. Also I like to keep things as original as possible.
I can kinda see that you like keeping things original, 351 and all...
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
But sometimes function has to win out!
My friend motoman, on a run when he was my passenger, finally suggested ( I suspect out of frustration!
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
) that I keep my right foot rested against the tranny tunnel. Then it's just a matter of rolling your foot, using the tranny tunnel as a steady-rest. That smoothed out my driving considerably. That and the throttle cable, and I'm damn near perfect!
![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
;D
Besides, you keep running that AFB, and you'll be converting to EFI soon enough... Ask me how I know. And then ask me if I want to sell that POS AFB I've been kicking around on the garage floor for two years!!!
