rjrobin2002
- Oct 13, 2007
- 2,706
http://cdn.wildhorses4x4.com/downloads/Turn Signal Wiring 06_30_08.pdf
I am installing a 77 column in a 73 Bronco and have researched the wiring and this is where I am at.
Theses are the same from 73-77:
L front "Green/White"
R front "White/Blue"
L rear "Yellow/Blue"
R rear "Green"
Turn Flasher "Blue"
To horn "Blue/Yellow"
Here are my questions/thoughts:
I am assuming I leave the 77 column Hazard "white/red" alone cause my hazards are on my dash.
I can run a power wire tied into my light switch to the 77 column "Blue/orange" wire to give me a indicator light.
What do I do about my 73 factory horn wiring "Yellow" that was my horn power?
And where does the turn signal switch get its power from?
R rear "Green"
Turn Flasher "Blue"
