Built your own gas tank?
br0nc0xrapt0r
Loves pickles
How many of you have done this? I need a new tank with more capacity and I'm thinking that I can make a tank for the fraction of what a new High cap tank costs. Really how hard can it be? Drop the old tank measure the space, bend the sheet metal and add baffles and a filler neck. I can cut out and add in my old sending unit from the ancient bent up rear tank.
HoldMyPocket
Charlotte
I thought about it but looked at the cost in materials and amount of work... seemed cheaper to just buy one that was already done... but I'm happy with a 23 gallon.
ransil
I'm in the process of doing it.
cost is not cheaper if doing a one off unless you cut & bend yourself.
I had mine drawn up in cad and laser cut & bent at a shop that right there cost more than a vendors assembled tank.
I'm a slacker cause I did this over a year ago and it still sitting as come from the shop, I still need to tack it together fit it and do the final welding.
br0nc0xrapt0r
br0nc0xrapt0r
Loves pickles
I bet I could do it for 200, not counting the cost of a sheet metal brake. Still 500 from WH is tempting but that is a big part of my budget. And a planned trip to SoCal from OK I'm going to need money and a bunch of gas at the same time.
br0nc0xrapt0r
br0nc0xrapt0r
Loves pickles
You sure your bugger welds will hold gas????
That is another one of my concerns, I'm a good mig welder but I do not have a tig so I would have to use some sort of tank sealer like the chopper builders use.
70_Steve
Old Guy
Here's a couple PDFs of a gas tank plan I snagged from this site several years ago. Never used them, though, so don't blame me if it doesn't fit!!!
  • Gastank1.pdf
  • Gastank2.pdf
bmc69
I build many...most in aluminum but have done some in steel and stainless steel too.
The tank in my '69 is aluminum, with a 1/4" bottom and sides. It's held up very well as a skidplate over all the years I've crawled rocks with it. The tank in the flathead EB project is all made with 1/8" aluminum, which is more typical of what I usually use.
I always TIG the aluminum tanks. The others I MIG and then fix any pinholes found during pressure testing with the TIG.
br0nc0xrapt0r
br0nc0xrapt0r
Loves pickles
Ok, so 50 bucks for a 4x8ft sheet of 14ga hot rolled and 70 for the cold rolled. I could do that and build an internal cage and baffle system with the cage providing the structural support and providing a mounting point.
br0nc0xrapt0r
br0nc0xrapt0r
Loves pickles
Steve, where did you get those plans? They look legit just like the vendors tanks.
Lonesouth, I will have to look at that link later I can't see it on my work computer.
I'm doing more research and I think I'm going to go for it. I can go with 16ga and bend it with a HF brake or 14ga and just cut it out and weld.
Right now I am leaning towards the 14ga since I will be able to turn the heat up on the welder and get better penetration for a better seal.
WorkerBee
Northern CA
I built my own. Yes it was cheaper but I work in a stainless shop with all the tools I could ever need and free scrap....
I used 18 gauge 304 stainless and recessed a factory explorer pump/sending unit. I placed perforated baffles inside and TIG welded everything. The fuel doesn't slosh at all.
I welded a donor inlet and stainless tubes for the vents. The pressure and return fitting were already on the sending unit. I made the heavy gauge mounts and utilized two existing holes in the frame for the back mounts. For the front I welded on old head bolts as studs. The factory body bushings worked great for isolators.
My calculations put it at about 24 gallons but I have not filled it completely full yet. It sits pretty high up there but I designed it like that on purpose.
My recommendation is to buy a new one from a vendor. The only reason I did my own was because of my resources at hand. If you don't have the tools I think you may be better off buying one.
I've had a lot of requests for bend files and auto-cad drawings and I am working on finishing those to share. for now, here's some pictures. I have a bunch more if you would like to see more.
rjrobin2002
That weld in picture 4 is maybe the best I have ever seen, and I weld alot of steeel and aluminum.
70_Steve
Old Guy
As said, I copied/downloaded them from a thread on this site years ago. The plans looked pretty decent, so I thought they might come in handy. The timestamp on the files is 2004.
This was before I bought my BC Broncos tank...
br0nc0xrapt0r
br0nc0xrapt0r
Loves pickles
The way I see it is that I already have a nice MIG so If I plan to do it out of 14 gauge then I already have what I need. I do not have 500 bucks to blow so its worth a shot. Dont take this as me blowing you off, I just can't justify paying a lot for something I can build.
70_Steve
Old Guy
If that was for me, no I didn't take it that way. My comment about the BC Broncos tank was supposed to be my way of explaining why I never used the plans. At the time I didn't have a welder, and the tanks were quite a bit cheaper.
Now I've got three welders. Go figure...
motoman made his own tank, and welded it up with a MIG and flux core wire.
http://www.emotoman.com/fuelcell/fueltank.htm
br0nc0xrapt0r
br0nc0xrapt0r
Loves pickles
This comment was for worker bee, he recommended that I buy one but its just not in the funds. Steve I will probably build your pdf one out of cardboard and see how it fits.
70_Steve
Old Guy
After you make it out of cardboard and check the fit, fill it up with water to determine the capacity!!!:p ;D
