I recently got my '76 running after better part of a year. Had the motor and transmission professionally rebuilt and installed them myself a few months back (302 and c4). Been out of town for work and I'm just now having time to fool with it. I'm having a few issues and looking for some advice.
I'm having issues with my edelbrock performer carb hot starting and I've read up on here and seems to be that I need to add a one inch spacer to control fuel temps under hood. I should note, I have an Edelbrock performer intake as well.
Is this the right one for my setup?
http://www.amazon.com/Edelbrock-871...1&keywords=Edelbrock+Carburetor+Spacers+8711#
Do I need to buy gasket to place between the manifold and spacer and one between the spacer and the carb or just use liquid gasket maker? If so which one?
Moreover, the motor seems to be running "hot". Its not to the point that it is overheating and steam blowing everywhere but after short drives around town and stopping the top hose going into the intake is under pressure when stopped and idling. The temp gauge is showing a high temp of around 210 degrees but goes down to around 190 after getting moving again. I should mention we busted the original fan shroud leaning over and tuning the carb. I have ordered another one from bronco grave yard. Is the fan shroud the main issue since it is a direct drive fan and the air can't "direct" over the engine like it should? Also, what is the correct temp for my thermostat that I should install a 160 or 190?
I plan on installing an aftermarket temp gauge today to double check the factory gauge and make sure it isn't running hot.
Thanks,
Trojan
Thanks,
Trojan
