bknbronco
Anybody seen a bronco with the front hoop lower half made from plate steel instead of tubing?
Like the jeeps i was kicking around the idea of making 1/4" plate steel lower legs for my front hoop. The 1/4" plate would run from the dash pad down the side of the dash to the floor. It would be bolted to the side firewall and could be bolted to the floor where you could also tie it into the frame.
Why the plate steel??? Tubing gets in the way of things like glove box door and also blocks view. Plate steel lower halfs would be tight to the body, allow you to still use a dash pad, and wont interfere with sight or geting in or out and will allow you to open glovebox door without any mods. Running the cage through the dash is alot of work and you still end up with problems with the glove box and dash pad. The plate steel idea seems to be a nobrainer?
I have a viewfinder windshield frame so i was thinking of bending the top half of the hoop from stainless steel and keeping it super tight to the frame (1/2" or closer). The lower plate legs could be made from SS or mild steel. I want the front hoop to be almost invisable and the stainless hoop would blend with the stainless frame nicely. Then id just weld the rear cage to that SS front hoop.
