Hello all, as some of you may have seen my 76 Ranger build the last year or so you know I will never take that one off-road. I recently purchased a great 1969 Bronco from a member here on cb.com that was being finished up after a frame off.
I have lots of ideas on how to make this great Bronco even better but before I do I have a few things on my short list that need attention that the previous owner didn't have time to get to before I barged in this last weekend
There is a vibration thats almost a jack hammer in the seat of the pants type that gets pretty bad at about 55mph. I think it might be the rear driveshaft so will have that rebuilt and balanced then check all the angles.. might be some pinon angles to play with - we will see.
Leak around the windshield hinge, not sure if this is the weatherstripping or if its leaking through the actual spot welds. I will test and see what we have going on...
Passenger door fitment and fender fitment. The PO replaced the door posts both front and rear as well as the rear quarter panels, so no rust! However there are a few fitment issues that I have been playing with on the passenger door. I think I might use a bottle jack or something similar to try and spread the door opening at the top... thinking this might not only allow the door to close correctly but it might also correct the fender fitment and allow the windshield hinge to seal better. I figure i will have to take the front passenger fender off and maybe even losen some of the body mounts to get it to move.. doesn't need much.. less than 1/4" is this a bad idea? anyone tried this before?
With the big block come big body lift. I would love to remove 1" of the 3" body lift.. probably need to go through and see what the options are may not be many as things are close with that 400 in there
Wiring cleanup and tuning.. both need to be done, PO got it running pretty nice but WOT and cold start are not tuned yet.. will have to work on both of these here soon.
Anyway enough yapping, here are some pics!
Lots to do but love working on the Bronco and can't wait to dive in!
