77BRONKOTN
- Sep 3, 2001
- 360
I'm posting some leveling results from my leaf removal today. I'm adding as much info as I think would be useful to others.
1977 3.5 11 pack devers. 6 degree shim plate. Duff 3.5 coils, single shocks and rubbers. Soft top/Duff plate rear bumper/tire carrier w/34/11 spare tire/jack. Stock front sway bar.
My truck never settled after a year. The rear was jacked up a bit. To the point of being really noticeable looking and driving. I removed the two smallest leafs from the 11 pack. Remember, I have the 6 degree plates which may account for a little more rear lift. Plates went back in.
The truck leveled perfect and a few other changes happened as a result. Even without degree plates, the level shouldn't be much different. Check your pinion angle and decide if you need them.
Inverted Y steering and wandering. The weight transfer to the rear helped this tremendously. While being ok at low speeds before, a bump at high speed was always unnerving. HUGE difference >>Letting off the gas or braking doesn't magnify the floaty feel like before. Drop pitman, no drop track bar bracket. Adjustable track bar.
Softer ride. My tailgate doesn't sound like its going to fall off hitting bumps at lower speeds. I do feel a bit more body roll as the rear is softer than before. I may just have got used to the stiff ride before.
Remove the whole pack from the truck to take out the leafs. A good vise is useful to clamp the leafs together, to get the bolt out and back in. Total time was about 4 hours.
In short, while trying to make my truck look better. I made it drive a lot better.
These are my results based on my combo. I wanted to put this on paper for others searching around for info, as I did. Hope this made sense or helps.
EDIT INFO: Bed/Back weight items,
Soft top
Standard 4 pt roll bar behind seat.
Heep fold tumble seat
Plate Duff bumper w/swinging tire mount w/16x7 285/75 (34x11.2) tire.
High lift jack.
15 lb tools
Empty box turtle shell? Who put that back there.
I removed the left leafs first, buttoned back up. Stood on bumper and jumped up and down. Left side soft. Right side even with tire/jack/carrier weight barely bounces up/down until I did this side. Bounces equal to left after removing rt leafs.
Before *Note* left of the concrete line is heading up hill. Illusion of the truck being level.
*On level ground the truck is level. This looks slightly saggy because driveway is sloped. Look close at the rear shock. Then look at the other pic. Here you can see the couple inches.
___________________________________
***UPDATE 2 June 2014 added Wildhorses T conversion and few days later Duffs drop radius arm brackets.
Wildhorses T conversion clears at the tie rod the same as the stock tie rod did. So if a wheel fits your stock 76/77 Bronco, it will still fit with the WH T conversion. The truck still wanders and high speed is a no no.
* Drop Radius bracket cured the wander. I set them in the middle hole of the bracket. Happy as a clam now.
_________________________________________
Also, E150 2004/05/06 4.5 backspace 16x7 285/75-16 tires FIT a 1976/77 just fine.
Soft top
High lift jack.
15 lb tools
