What's that tapping?
crews44
Mullica Hill, NJ
Rocker arm with incorrect lifter preload. I have same thing going on right now. May need a longer pushrod and rocker shims to get perfect if you have pedestal mounts.
Everybody says just torque them down but there is a little more to it than that.
Does is seems to follow engine rpms?
airbur
airbur
Castle Pines, CO
Yes...it doesn't go away. Follows the RPMs. Well, if that's it, at least I got the other 15 correct:) Guess I'll be removing the valve cover.
crews44
Mullica Hill, NJ
Make sure cam is on base circle and you get proper torque at 1/2 to 3/4 turn after zero lash on pushrod. I had to go with longer push rods and then shim accordingly under pedestal to get it where i was at 1/2 turn to get to 25ft/lbs.
I had heads on my 351w and had same noise. Same on my 5.0 now. Got one head good by going this way. Still have to get PS head done.
crews44
Mullica Hill, NJ
Yeah...the combustion stroke. You can do it where when one valve is open the other is on base as well. If you want to do it as one cylinder get on compression stroke.
airbur
airbur
Castle Pines, CO
Yea.....realized it about impossible to rotate the engine. I have the Explorer serpentine and can't figure out a way to do it manually.
crews44
Mullica Hill, NJ
Well, it's a Cheby site but....this works... http://www.small-block-chevy.com/cb_6.htm
This accurate if you use stud mounted rocker arms( a nut, not a bolt). You have pedestal mounts with a bolt down thru center I imagine. Thats where the torque reading comes in.
The stud mount are set by number of turns from zero lash. Pushrod length is not really as factor unless your'e building a high revving race motor where you need perfect valve train geometry (another topic) There is a lot more room for adjustment before switching PR length.
The pedestal are not as adjustable or forgiving. Your required to get 25 ft./lbs of torque on the bolt between 1/2 and 3/4 turn of lifter preload. PITA as you have to have correct length pushrod.
crews44
Mullica Hill, NJ
I have same thing. Get stubby 1/2 drive extention on a short 15/16 socket. Its tight but doable. Or pull coil wire and bump starter till you get one lifter up and adjust other rocker.
nvrstuk
PNW
E-
How's the volume and the pitch of the sound IF you held your video camera below the headers the EXACT same distance as the camera is when taking this video? In other words, have you listened to the sound with your head below the headers to eliminate the chance of an exhaust leak causing this sound? My cheap spkrs at work make it hard to really determine the tone/pitch of the sound, that's why I'm suggesting this.
airbur
airbur
Castle Pines, CO
Viper suggested the same thing. I listened to it from all angles and even got down and checked for leaks. Also tightened up a few header bolts. Noise is still there.
TwoDalesDad
Do you have screw in studs? ..Or Are they Press in studs..."... Your Rockers"..I have had the studs lift out of the head...on more than one engine...mine once....others...more...Then you can not adjust valve correctly...keep lifting...
airbur
airbur
Castle Pines, CO
I just opened it up and readjusted #3 and 4....all 4 rockers. Put it back together and same noise. I didn't do 1 or 2 because it really sounds like its coming from 3 or 4.
Not sure on the studs...I think they are threaded.
airbur
airbur
Castle Pines, CO
It's brand new....can't imagine I blew it out in under 2 miles of driving.
And it was doing it the very first time I started it up.
