Vendor question/ help- P heads headers
Quackhead16
Do any of the vendors carry headers that will fit the p heads for a 01 explorer swap. Or does anyone know where I can get them? Thanks
JGZ
Call Melissa at Bronco Hut.She can hook you up.303-663-1455
01Dudley
Knoxville
x3 and they are made in the USA by Sanderson Headers. I wish our full lengths would clear the "P" heads dangit!
garberz
Bronco Influencer
Conejo Valley, Ca.
Quackhead16
Quackhead16
Do y'all know if stock mustang (fox body) manifold will work with the p heads?
Quackhead16
Quackhead16
I'm just using the stock Explorer manifolds. They don't leak. I have them already and I'll still be able to get to the spark plugs.
Mark[/QUOTE]
Are you running "p" heads? From what I understand and have read the stock manifolds will not fit in an EB.
Tito
CB Fire Starter
Bakersfield, CA
If you are running a mech clutch you will have issues on driver side but auto they seem to fit fine.
I run bronco manifolds on mine, ground down around the couple spots where it was tight. I have p heads.
garberz
Bronco Influencer
Conejo Valley, Ca.
I running a C4 auto. Visually, they seem to fit as good as the stock Bronco manifolds. The drivers side will interfere with any mech. clutch linkage. With the auto, I should be fine. I'm going to put the Explorer manifolds on my stock 302 and get my exhaust ready for the swap. I'll be doing that in the next few weeks.
Mark
Quackhead16
Quackhead16
Thanks guys. I plan on running so I'm going to try and run the stock manifold, hopefully it will fit and save me a lot of money.
