WheelHorse
- Nov 22, 2004
- 2,491
Stock 302, stock 2-1 exhaust with glasspack. 76K original miles.
2150 1.08 carb
Idle vac steady at 21
Timing total 32 under WOT: 12 base, 20 total mech. I was at 36 total, no adv and had some rattle, backed it back down to 32 total.
Vac mod timing 10...starts adding around 7" and is full 10 degrees by 15"
Vacuum while cruising 15-17 at 60-70 mph.
At 8" I can see the powervalve adding fuel on the wideband. She'll go from the 15-17AFR to 13's under 8" of vac. I would like to see 12's.
Idle...is steady at 14.5-9 AFR.
Slight tip in results in 19 AFR ?????
Highway is high 15 through low 17.
WOT...If I go WOT and hold it, she's at mid-high 13's...lean in my book
If I'm cruising and give a blip, the WB meter show's instantaneous high 12's and quickly leans back out, so accel pump works great.
If I lift to around 3/4 (going from WOT to 3/4) she momentarily go into the 12's but right back to mid 13's.
Carb was dipped for 48 hours, was in good over all shape. Through a Walker rebuild kit including power valve that came with it.
I have checked the fuel level with it running and away from the sides of the bowl, was dead on to whatever the spec had called for. I can look it up when I get home.
1) She was purchased in Texas and then lived in Denver. I'm wondering if stepping the jets up would bring the WOT to the 12's and the cruise to mid-14's. OR is this simply a power valve issue; needing a Holley PV to allow a bit more fuel in; if that's possible. Not sure on flow of either one. IF my feeble memory serves me well, I want to say the jets are 47-48.
2) The extremely lean 2-4% part throttle is concerning.
3) I will get the soapy water spray bottle out when I get home. My first step will be to verify if there are or are not any vac leaks.
First ride in this morning with the wideband, so I thought I'd throw this up to see if anyone else has come across this or has any constructive mentionables that may help a future member down the road.
Thanks for reading.
2150 1.08 carb
Thanks for reading.
