Another Bukin Suspension Mod
Bukin 67
Bronco Abuser
Not a huge project, but I'm going to run a thread on my suspension and cage build.
Currently, it's a '67 sport with:
D44 front, 9" rear
3-1/2" suspension lift, 2" body lift
WH hoops in front
WCB Long Travel Tubular Radius Arms
3-1/2" 11 pack leaf kit in rear
Stock track bar, tie rod and drag link
F100 steering box and HD Delphi PS pump
Stock main and aux fuel tanks
35" tires
BG(?)6 pt 2" Family Cage kit
Starting out (lol), the new mods will consist of:
Stretch approx 2" and 4 link the rear
Replace track bar, tie rod and drag link with 7/8" chromoly, heim system
Replace F100 inside frame with F150 outside frame steering box
Add ram assist
Custom fabricated radius arms.
New chromoly cage to accommodate suspension
Custom fab spare tire rack
2-1/2" Fox coilovers with 2" bypass
23 gal fuel tank
It's in the shop, ready to begin :D :
Bukin 67
Bukin 67
Bronco Abuser
Also, I will be parting out the stuff I'm replacing, so I'll post them up in the for sale section.
Bukin 67
Bukin 67
Bronco Abuser
Started removal of old parts to be replaced: shocks, main and aux. fuel tanks, roll cage, dual batteries..
Bukin 67
Bukin 67
Bronco Abuser
Now that's what I call a frame-off :eek:
The templates for the trailing arms are off to be laser cut, then we'll be starting fabrication of the tubular rear frame, cage and 4 link.
Bukin 67
Bukin 67
Bronco Abuser
Started fabrication on the 4130 rear tube frame, cage and shock mounts.
Installed the 23 gal. gas tank. :D
Triangulated bottom/side supports, 4130
The rear tubular frame will net me about another 4" at full bump
Bukin 67
Bukin 67
Bronco Abuser
Boxed in the rear frame transition to the tubular
Building the supports for the radius arms and trailing arms
Started fabrication the rear trailing arms.
u10072
I like a trailing arm that has the suspension mounts on them-- ala offroad race trucks. Are you planning on some inner body mods to get the extra 4" of bump travel? I found that the frame as well as the body starts to limit the amount of bump travel, especially as the tire size gets bigger. Are you going to be mounting the shocks to the cage structure?
Bukin 67
Bukin 67
Bronco Abuser
We cut the stock frame behind the trailing arm mounting point and tubed it out to get extra up travel (see pics above). We also had to cut the bed and make a cavity where the pumpkin bottoms out. The frame tubing will all be tied in to the cage, which will also support the upper shock mounts. We're still estimating at this point, but looking at 18-20" of travel
broncoitis
Nice work so far! Gonna be pretty cool when your done. Seems to me that this is gonna be more of a Desert style prerunner? Can't wait to see what you do with the cage. ;D
Bukin 67
Bukin 67
Bronco Abuser
Thanks Broncoitis.
Because I do a lot of open desert running, and I chase for a race crew, I'm looking to end up somewhere in the middle, 1/2 pre-runner, 1/2 crawler.
Our last run, earlier this year, was 730 miles. We started by Randsburg, CA, headed E/NE and looped up through southern Nevada and ended up by hwy 395 south of Lone Pine, CA. I still love crawling. It's just 2 totally different experiences.
BTW, if anyone wants the .usr files from any of our runs to load the tracks into a Lowrance, pm me.
Bukin 67
Bukin 67
Bronco Abuser
Here's a couple of WIP cage pics..
stlo
tulsa
very nice.....good looking cage design....has a clean look to it....i like it
Lmfp
Lake Charles, LA
I've been waiting for someone to do a suspension setup like this. id love to do that to mine but i dont have the tools, know how, or money for that job. Cant wait to see it finished though.
u10072
Its funny how the cage in my Victoria project looks almost exactly the same as yours :) Very cool race-inspired design!
Bukin 67
Bukin 67
Bronco Abuser
Thanks u - I looked in your gallery but didn't see your cage design. I did see your exhaust dump out the sides, which is exactly what I want to do - right down to the s/s sleeves on the body. Very nicely done.
We basically designed the cage around my soft top size limitations, with the necessary reinforcement built in.
Bukin 67
Bukin 67
Bronco Abuser
Sexy time!
Further work on the cage
Rear housing link tabs..I know those tabs should be on a nicely custom built Currie housing with disc brakes, but that will just have to wait for the next mod :(
Bukin 67
Bukin 67
Bronco Abuser
Upper 4 link mounts done
