Hanson Sales
- Apr 27, 2007
- 5
Back into production, our dual post swing away bumper and tire carrier is available for order NOW!
The Famous Hanson Offroad Double Swing Bumper is back! The handcrafted construction of this bumper exhibits the style of the most copied bumper line out there. It consists of 3/16” cold rolled steel, 3/8” end plates, 2” receiver hitch, and 1” clevis tabs. The bumper allows you to run a right or left side spare tire and a wide combination of Hi-Lift, RotoPax, Standard Jerry Can, or cooler mounts. Uses low maintenance double cam slam latches. The combination of sturdy constructions and multiple angles adds strength and optimizes departure angles. The unique placement and design of the 1” wide clevis tabs gives them unmatched strength allowing them to be pulled from any angle without fear of damage to bumper or tab, and they do not interfere with departure and approach angles. Frame reinforcement brackets and hardware are supplied to ensure secure attachment to the Bronco. Bumper is finished in semi-gloss black powdercoat.
http://hansonoffroad.com/proddetail.php?prod=EBRTC-P
![ebrtcp_v2_20140102_medium.jpg](http://hansonoffroad.com/prodimages/ebrtcp_v2_20140102_medium.jpg)
![ebrtcp_v1_20140102_medium.jpg](http://hansonoffroad.com/prodimages/ebrtcp_v1_20140102_medium.jpg)
