- Aug 27, 2001
- 5,150
I have a stock '77 Ranger w/original 302, 73k miles that was running great, and now won't start. I put a new rebuilt Motorcraft 2150 carb on it from National Carburetors a few months ago, and been doing great until yesterday morning when I tried to cold start it. It's been a little hard to start on 20 degree mornings, but always starts and dies a couple of times before actually idling on its own and then runs perfect. Did the usual pedal pumps yesterday, turned the key and it just kept cranking and cranking. It seemed a little bit like it wanted to fire, but then just kept cranking. Carb is squirting plenty of fuel ( two good solid streams) I used another good coil and good Duraspark module from a running Bronco to test to see if either were bad, so that I can seem to rule out. Connections seem to be in good shape. Any ideas? Rotor cap and button seem in good shape too. What would cause it to run one day and then only crank the next?
Thanks,
Blue71
Thanks,
Blue71
