dana 20 t-shift twin linkage stick pics??
jperry1290
Can you guys send pics to jperry1290@gmail.com of the linkage for a dana 20 t-shift twin stick. I made my own shifters but the linkage is binding. I did my best to replicate the jb fab model.
Viperwolf1
electron whisperer
Unless you've done internal mods the rear side needs to go into range (high or low) first, then the front can be moved into that range. When coming out of high or low the front needs to be shifted first, then the rear.
Airmapper
Foolproofness Tester
Bowling Green, KY
This page has some info and pics:
http://www.wt4x4.net/tech/twinstick.htm
This is the modification Viper is referring to that you need to make for a T-shift to be fully independent for front and rear drives. You have to cut out where the red lines are, and it's a good idea to weld up the rear low detent recess a little so it stays in low better.
This is my T-shift with the JB fab twin sticks installed.
Viperwolf1
electron whisperer
Here's a better pic of some modded T rails.
jperry1290
jperry1290
how long is the pivot bolt mount. I think that is where my problem starts as the bolt flexes and bent throwing everything out of wack.
