Dealer A/C on board air setup
Seventee
In the sticks of MT
I wanted to post a thread about this in case someone else runs into this issue. Thanks to a suggestion from PAPITT I finally have a working on-board air setup utilizing dealer installed A/C parts.
I bought a compressor bracket from a member here but it was missing the idler pulley. The picture below is an example of what I have (not mine):
I tried to find an OE idler pulley and eccentric adjuster with no luck. PAPITT clued me into finding these items at a parts store and sure enough they are available, but not listed for an EB. This is what I bought, for around $40:
These parts worked perfectly, no shimming necessary. The eccentrics are available in several offsets - this one is 2 inches. I bought the bolts separately - the eccentric takes a 1/2 fine thread and the pulley uses a 7/16 fine thread. This is a pic installed without the belt:
While I'm at it, this is the belt I ended up with in case someone has a question about it. The parts stores do not list A/C belts for EB's, probably due to the fact it was a dealer add-on:
Thanks again PAPITT, you saved me some headaches! :cool:
Seventee
Seventee
In the sticks of MT
I had a couple requests for more info on this setup, so I took some pics and decided to add to this thread and change the title.
The compressor is a York 210 out of a 73 Ford wagon that I wrecked in a demolition derby years ago. I wired in a simple toggle switch to engage the clutch. The fittings are standard pipe fittings. I had to grind the upsets off the 3/4 inch elbows so they would screw all the way on and clear the head bolts on the compressor. The breather is a standard 3/4 inch push in style for a valve cover. The 90 degree hose is a coolant bypass hose for a 302 water pump:
I changed the wagon's single groove pulley with inertia ring to the EB style double groove. Two reasons - the large inertia ring found on some compressors may contact the underside of the hood without a body lift, and the pulley alignment is slightly different which would have required me to re-drill the bracket and move the compressor. Rather than re-engineer everything, I took the easy way out. The double groove clutch assembly is Four Seasons part no. 48531 and it cost me $63.00:
I picked up a 3-groove crank pulley from another member here. A couple more pics of the belt routing:
I run Saginaw power steering and a 7-inch case 3G alternator. The 3G fits just fine in the bracket under the compressor. But if I ever have to remove the alternator I will probably need to pull the radiator. There just isn't much room around the passenger side of the engine with the compressor and bracket in place.
I tested the system by filling a spare 30-gallon air tank I have in my shop. It took 3 minutes to air the tank up to 35 psi with the engine idling at 700 rpm, so I should have no problem airing up tires. :cool:
broncojo
Lewis Run, PA
Did you have to alter the factory A/C bracket any or did it fit on good, I've seen a few of the A/C on Broncos mounted on the drivers side. Looks like you may have fabricated a mount for the idler pulley. I'm interested as I want to do the onboard air and already have a compressor. Other than that it looks like a nice clean install. Thanks
Seventee
Seventee
In the sticks of MT
I did not have to modify or fabricate anything other than the fittings on the compressor. Everything else was bolt-on. The idler pulley/adjuster attaches to the end of the A/C bracket, as seen in the first picture in this thread.
broncojo
Lewis Run, PA
Good deal then, I'll have to keep an eye out for something similar. Would make the install a lot easier then fabricating one. Thanks again
bmc69
If you want to have pressure control, McMaster Carr sells a nice little pressure switch that threads in to 1/4 or 1/8 NPT hole. Or...an old shop air compressor switch works too..but is a lot bigger.
I've used both.
Seventee
Seventee
In the sticks of MT
I've used both.
For the time being I reversed the air fittings and will run an open ended air chuck for tires. That way I won't over pressure the system. Eventually I may plumb it into my front bumper, but I need to rework the bumper first. At that point I will add a pressure switch and blow-off valve.
