SavageBurro
- Aug 12, 2013
- 588
Has anyone ever run 95-2000 Tahoe leaf springs in early bronco?
Looks like they are a total of 6" longer with the center 3" further back. Width is 2.5" and spring capacity is same as bronco at 1750lbs.
I was thinking they would be a great way to move the axle back 2.5 - 3" while providing decent flex and good ride. I haven't measured to confirm whether there is room for a rear spring hanger, but it would be close. Hanger would not have to be a full 6" back cause when ya go shackle flip, the hanger moves forward a tad in relation... to get the shackle at an angle when at rest.
I know its sacrilege :-X to even contemplate a chevy part on a bronco... other than disc brakes of course.
I haven't completely finished my suspension changes, but I moved my Sterling 10.25 back 2.5" by doing shackle flip, homemade longer shackles and making longer spring perches with the hole 2.5" forward of center. This is a magic distance so I can use a stock length driveshaft on 3.5" lift and the longer sterling pinion.
What I'm afraid of is the rear part of the u-bolts barely come up where the spring pack is still compressed together... and the springs may not perform as good as if the axle were centered. The chevy springs seem like they would resolve these issues.
I will try my setup out since I already spent the time making hangers and shackles and figuring out heights etc, but if that doesn't work out, I will have to go a different route... soo... if someone else has used the Tahoe, Yukon, denali, escalade springs, it would be great to hear from em.
By the way there is enough clearance (just barely) between the back of the diff and the crossmember / gas tank at full stuff with the axle back 2.5".
Thx!
Thx!
