77-302
See last page for (tear down) update....
Started to tackle the d20 removal so that I can replace the high speed gear and bearing/seal and ball detents.
Removed front and rear driveshafts
Removed exhaust
Supported trans and removed cross member
Disconnected speedometer cable
And started on the six bolts around the adaptor to the C4
Just as people have stated...the top two bolts on the drivers side are a B}*%€H!!!
I got the lower one out but even with a stubby I can't get the top one to break loose.
Upon closer inspection I'm not the first to tackle T-case removal.
The tunnel is hacked to hell and a the Previous owner put in a patch panel with 1" long screws and then bent them over to make clearance for the tcase.
This isn't evident from the interior since it has a nice thick insulated vinyl floor put down.
So the dilemma begins....
To remove carpet I have to take seats out.
To take seats out I'd have to remove the Aux tank (I don't want to do this)
The only option I think I have is to cut the vinyl floor to expose the tunnel and cut my own hole into the tunnel.
Removing the existing patch panel will require me to make a huge hole in the vinyl so I think I'm going to have to do a patch on a patch.
This will screw down on top of the vinyl flooring and I'll use either aluminum or stainless to make it presentable and glue insulation on the back side to keep noise and heat out.
Anyone got a better idea?
Removed exhaust
