Crate Engine Recommendation
Johns Creek, GA
All,
I'm in the process of finding a new engine for my '75. I had originally settled on Proformance but they're simply too expensive. I then looked at Phoenix but was worried about several reviews.
Do any of you have a solid source? I know Summit is the stand by for a bunch of folks but I'm looking for the best value/quality combo.
Looking for 302 with high torque.
Thanks in advance.
DJs74
I suggest visiting your favorite local auto part store (Napa / CarQuest / Orielly's / etc) and talk to them and see what they have to offer dollar wise and warranty wise - they might even custom order you something to your specification.
Even if it cost you a few bucks more, at least you have the store as a partner / ally in case something goes wrong or problems arise - otherwise, if you go strictly internet - you are pretty much alone dealing with problems if they arise
DJs74
A
Johns Creek, GA
Thank you DJ and Tim.
I have spoken with local parts suppliers and they all come back with Jasper and Summit.
I'll look into Promar.
Hard to believe there are so few options but I guess it is not a high volume business. Heck, took me 10 years to decide to do this on my '75.
jw0747
San Antonio, TX
Have your engine rebuilt by a local machine, engine or speed shop with parts they recommend to make it like you want it.
Timmy390
Conway, AR
Jasper builds their own but Summit is just a reseller. They buy from many different sources and resale. To get the Jasper warranty you will need the engine installed by a jasper approved shop.
Tim
zonian
St. Augustine
mritchy....if you don't mind, what was the ballpark in cost for the ford engine? Thinking the same thing. Thx, Dale
DJs74
x2 on this one
or at least put a "rebuild at your local shop" on paper and compare costs to a turnkey crate motor
You have your platform now (your current 302), just try to work with your local auto parts house / machine shop and ask them to run through a rebuild scenario for you. Ask them to include all machine work (cylinder boring, cylinder head machining, crank turning , etc) and then add new component costs (camshaft, pistons, timing sets, gasket kits, etc) and then ask for assembly labor. You'll have a price for the rebuild and then can compare that number to a crate motor delivered to your door. Piece of cake
DJs74
dao1980
Chattanooga
I had a good experience with Promar Engines.
They were happy to slap a nice cam, GT-40 3bar heads with Scorpion rockers on it, and did it very quickly.
A
Johns Creek, GA
Great feedback, thank you everyone.
Just hung up with local engine shop, they are going to come up with some options and present to me tomorrow. Seems like a less expensive route (adding in the local aspect in case of issues).
Timmy390
Conway, AR
My local shop is charging me $487 for the machine work on the block. I'm doing my own heads(cleaned them up, lapped the valves and installed new vale stem seals).
I took them a disassembled block, crank and old pistons/rods. They worked the block over giving it a .020 bore, new cam bearings, line hone, a couple good washes, reconditioned the rods, put the pistons on the rods and painted the block.
I'm doing the assembly myself. The engine kit cost me $400. I used the kit they suggested but you can get one from Summit for $350-$400 depending on what you want. My kit did not include a cam as I'm reusing the roller cam and lifters.
Tim
mritchy1
I Summit has them with intake carb and distributor For just under 5500
DuctTape
Bozeman, MT
I used engine factory. Not the cheapest route probably.
Think hard on the 351 option. If I had it to do over that's how I would have gone.
blubuckaroo
Grease Monkey
Ridgefield WA
Tim
This is an important thing to consider. Jasper isn't the only builder to require this. The warranty could end up scrap paper if you don't meet all the details. It doesn't even matter if you are capable of a better installation than their approved shop. And who could blame them? There are more than a few goobers out there.
gr8scott
Really? Napa deals with ATK. Napa part # HP99F:
ChrisC74
I don't have a NAPA close to me.
AuburnTiger - your tag say Johns Creek, GA - if that is current the NAPA in Suwanee is about 10 miles from you.
NAPA AUTO PARTS
Genuine Parts Company
1029 Industrial Court
Swanee, GA 30024
(770) 904 - 6515
That being said - I don't know anything about ATK engines.
I am just up the road from you in Sugar Hill.
